Tangent from circle
All  1-14  15-20
2788.15 In reply to 2788.14
Would this work in other situations?
2788.16 In reply to 2788.15
Hi Burr, that's a cool one, I think that does work because you basically form this isosceles triangle here:
which has the same angles as the extended one:
But sometimes it can be hard to remember a method that involves drawing things in a kind of different initial direction than what the main goal is though.
2788.17 In reply to 2788.15
Hi Burr - for speed, I would think that your method there is going to be the fastest since you get the right snap point after creating just 1 construction line.
Not much room to get much faster than that...
2788.18
Thanks Michael and Burr !
From what you guys showed there I ended up refining it a little further :)
Type the angle, one construction line.
EDITED: 20 Jul 2009 by DANTAS
2788.19 In reply to 2788.17
Just to be clear, if I was going to do any kind of isoscele, I would have to go out to the backyard and dig that guy up and take his bones far, far away! :O
2788.20
This old thread is the first Google result for "moi3d construct tangent", so I wanted to put a tip here that I just found out:
If tangent snapping does not work ("Tan" doesn't appear) it's probably because the point at which you started the line is part of three-dimensional geometry and the point and the circle are not aligned in the third dimension.
Show messages: All  1-14  15-20
