first Questions, how to get hard curves in a smooth surface and etc
All  1-2  3-6
2767.3 In reply to 2767.1
Hi nukkkle, also one more note:
> B.How can i make a surface bewteen B and C . B is
> one part of a whole curve that i cant, select, how to?
It looks like you do actually have a surface edge there that will give you what you need.
However, there is one of your earlier construction curves running over top of it, and independent curve objects have selection priority above surface edges, so it is hogging the selection.
To solve this, select that long curve and hide or delete it to get it out of the way. That will then make it possible for you to select the surface edge.
It's not a bad idea to get in the habit of hiding or deleting your construction curves after you have built a surface from them if you plan to do stuff to edges later on.
2767.4 In reply to 2767.2
thanks michael you re a machine, this answer took you only a couple of minutes, lightspeed service,,thank you very much :) i appreciate that
2767.5 In reply to 2767.4
Hi nukkle, no problem, glad to be of help! :)
By the way, I posted one other note above at the same time you were replying, it may be easy to miss it when that happens.
2767.6 In reply to 2767.5
i ve already seen it :)
Show messages: All  1-2  3-6
