Hi bisenberger, I'm glad that is working for you now.
That FBX version 2009.3 actually should be fine, that matches the FBX library that MoI currently uses and it is fixed up a lot from the stock one that comes with the default install from older versions of Max.
Additionally, you may be able to get vertex normals to come over properly now which helps a lot to get better quality and smoother looking shading.
