[Request] Environement Maps + Zebra !
All  1-7  8-10
2764.8 In reply to 2764.7
Thanks for all
I have the latest Beta. Ive buyed MoI just by looking at the jelly pot tutorial and doing 2-3 booleans on the trial.
Already done a watch and lot of medical devices with it, complexe impossibles booleans for poly modelling. And its so fast !
Im not even thinking while modelling with MoI, Im even more faster than co-workers with Lightwave and Modo, and I produce cleaner meshes.
MoI is like sketchup, once you see it you buy it :D
Ive done some low-poly modelling with MoI also (thanks n-gons) I found myself working with MoI for things I was doing in Sketchup.
Wish I can share my works (at least a render) but I cant for now, the watch is not on the market yet same for the medicals :)
I also wish I had time to model things at home with MoI. (space ships !)
Changing the style color is an option, but it would be cool to have a color box somewhere in the options to change the default black lines
without messing with css / cfg / ini files.
I cant wait for MoI v3, environements maps gonna be awesome for very organic modelling, when you dont have really hard edges.
MoI only need more advertisements, the only one I know is on cgdigg website, to be a block-buster !
Maybe organising modelling contests on 3d forums like CgSociety, 30 days delay (the trial time) on an unknown software, that would be awesome :)
2764.9 In reply to 2764.8
Hi DesuDeus, it sounds like you're having a lot of fun with MoI, that's very cool! :)
I hope that when the project you are working on is released that you'll maybe be able to share some images, it is always fun to see what is being done with it.
> black lines without messing with css / cfg / ini files.
Yes, actually in MoI v2 you can change the default color without messing with any config files, that's only necessary for MoI v1.
For MoI v2 the colors are controlled by the styles, so if you edit the default styles you will also be controlling the default colors as well.
To set that up, go to the Edit styles dialog, which is available on a drop-down menu on this part of the Scene Browser:
Choose "Edit styles" from the menu that pops up when you push that little arrow, and then on that Edit styles dialog, select the one named "Default" at the top and push the "Edit" button. That will allow you to change the name and/or color of that style, edit the color to whatever you want.
Now you'll see that when you draw objects, they will appear in that color that you picked there.
To avoid doing this on every new modeling session, you can save your altered style setup to a 3DM file (just with File/Save As) and then specify that file to be used as a startup template, which is available under Options > General > Template file.
When you specify a template file, it will load all the stuff from that file when you start a new modeling session including all the styles from it.
Hope this helps, please let me know if you have any problems setting it up.
2764.10 In reply to 2764.9
Ive never had the idea to make a template 3dm, thanks :D
Yes I will share my images, I just dont know when im gonna be able to do it.
Keep up the good work, and thanks for all the time you take to answer MoI users :)
I dont have anything else to say about Environement Maps so if any of you have, use this thread.
Show messages: All  1-7  8-10
