MoI - Big Wishlist thread - Post your wishes here
 1-5  …  86-105  106-125  126-145  146-157
275.126 In reply to 275.125
For the fractal I refound the free father prog Fractint :)
http://spanky.triumf.ca/www/fractint/fractint.html (dos)
http://spanky.triumf.ca/www/fractint/getting.html windows :)
free Chaos Pro the son of the father :D http://www.chaospro.de/
Free Fractal explorer http://www.eclectasy.com/Fractal-Explorer/
EDITED: 16 Feb 2007 by PILOU
275.127
New small wish about images : Control the size with numbers, not just those grips...more accurate
275.128
G1, G2 and G3 Surface filleting!
Maybe its already on the wishlist, I didnt read the whole thread:-(
275.129
How about a "Split Edges" feature when exporting OBJs?
Since OBJ files don't support creased edges, when the resulting mesh is subdivided in a subdiv modeler, all the edges will sharpen unless you tediously assign creasing.
"Split Edges" refers to the fact that in the obj file, edges that should remain 'sharp' are exported as 2 closely spaced together edges seperated by small joiner polys. This edge then will remain sharp even upon subdiv in a modeler.
Another option, is to support the Collada subdiv format, which allows for creasing, or the Silo SIA format, which also allows setting edges as creased. SIA is a really simple format, a lot of other 3D apps are getting importers for it, and I think SILO and MOI are a potential match made in heaven. Model your tank in MOI, give it battle damage in Silo using Displacement Painting. Maybe if you ask nevercenter nicely, they'll give you some docs. :)
275.130 In reply to 275.129
Hi Crusoe - I guess I don't understand why this feature isn't provided in your sub-d modeler environment.
OBJ files do support the concept of sharp rendered edges within the file. For example, if you draw a cube and export it to an .obj file, you should see a sharp-edged cube when you import it elsewhere.
The cube should have sharp edges because MoI wrote different smoothing information for each face even though the faces share the same x,y,z point locations.
If you want to preserve this creasing in your sub-d modeler, shouldn't they have a method over there to preserve the existing creasing and assign a crease to every current sharp edge?
Maybe I don't quite follow what you're asking for though...
275.131
But when you subdivide the cube, those edges don't STAY sharp. A edge that stays sharp, even when subdivided, is called "Creased", maybe I should have been clearer. :)
Here's a example:
The top cube has been subdivided 3 times, and now looks like a sphere.
The right cube has 2 edges creased, these edges stay sharp even as we subdivide.
The left bottom cube has 2 edges with a slight bevel. These stay somewhat creased as the cube is subdivided. It depends on how close I can make the 2 edges when beveling. The closer they are, the more it will be creased. If you add a 3rd edge between the 2, it stays even sharper when subdivided.
Ideally, collada (which supports creased edges ) export and X3d would be nice too.
EDITED: 21 Feb 2007 by CRUSOE
275.132 In reply to 275.131
Ok.... But the subd modeler has received the information about the original sharp edges of the model, for instance the edges of the cube.
It seems like your problem would be solved if they had an improved method for building creases, such as building a crease for each sharp edge in the original model that they currently already know about...
Wouldn't that solve your problem? That would also be a more general purpose solution for working in there because it would enable creasing on any imported model.
It seems like a good entry for the Sub-d modeler's wishlist instead of MoI's...
275.133
Thanks again for your attentive and thoughtful replies to my questions.
This has possibly already been requested-
The option to lock and inverse lock objects would be helpful
when you have a lot of objects and you want to develop
a specific part, without having the other stuff get in the way,
while having the rest of the model as a visual and operational reference.
( object snaps would still work on the locked objects)
The image is of Rhino doing it's best MoI impersonation :-)
The grayed out curves are locked, the blue curve is "live".
-Jesse
275.134 In reply to 275.133
I had been thinking of including this along with the whole package of object grouping / organization / properties stuff for V2.
275.135 In reply to 275.132
The problem is when exporting from Moi, the mesher produces a lot of edges. Some of them don't need to be creased as they are part of a gently varying surface, some do ( IE, the edges formed by 2 intersecting surfaces which do not have G2/G3 continuity? ).
So you need to export with a decently high polygon count so the subdiv surfaces approximate the nurbs surfaces when subdivided. But this high poly count makes hand selection of edges somewhat tedious.
I know it's a limit of the OBJ format, but exporting in a way that keeps sharp edges sharp would be nice. Whether it's doubling certain edges up in the OBJ export, or exporting a subdiv format that supports creases (collada), I think that this would be useful too.
Might be something to consider for V2. :)
275.136 In reply to 275.132
I think you're misunderstanding how subdiv modeling works. Unless the edge is weighted as 'creased', it's subdivable. All edges are created equal. And importing a cube and letting the edges subdiv is prefectly fine. A lot of humanoid models start out as a cube, with is cut, extruded, subdivd, etc. The original points of the cube can be considered the control cage of the subdivd model, you can drag them around to affect the resulting subdiv'd mesh.
If you want a edge to stay sharp on import, you mark it as 'creased' in formats that support it, or you double up the edges by defining a very very very small bevel in those that don't ( obj ).
This is important when I'm modeling something in moi that contains both gentle curves, and hard edges. When exported as a mesh, and imported into Silo ( To sculpt some blast craters ), as I subdiv the model, all the edges would go soft, as you can't denote which edges should be creased in a OBJ file.
I'll post a simple example of what I mean.
275.137 In reply to 275.135
> continuity? ).
Hi Crusoe, sorry, I'm still not quite understanding what you're saying....
Information about shared smooth edges (as opposed to sharp) is being written to the OBJ file currently, actually in 2 different ways.
Each polygon face in an OBJ file has a set of vertex normals on it that are used for shading - each face on either side of a sharp edge uses different vertex normals to make a sharp crease there (a break in the shading). But when there is a shared surface normal along that edge (surfaces connected in a smooth-tangent way for example fillets), each face along those edges will refer to the same shared vertex normal, unless you have unchecked welding.
So by examining the vertex normals of adjacent faces, an application can know whether that edge is sharp (different normals), or smooth (same normals).
In addition to this there is smoothing group data which clusters together all the faces that belong to one connected smooth set, this is additional data that an application can use to know about where sharp edges are in the model - there is no sharp edge between 2 faces within the same smoothing group, but there are sharp edges between faces that are in different smoothing groups.
So I don't understand why you think this is a limitation of the OBJ format... This information is included in the OBJ file that MoI writes.
If a target application doesn't process this information it isn't a fault of the OBJ format itself, it means the application needs to look at the data to harvest this information.
It seems like that's why they should include a feature that puts creases along all sharp edges in the polygon data, but not along smooth edges.
275.138 In reply to 275.136
Hi Crusoe,
There is information in the OBJ file about which edges of a model are sharp, and which are smooth.
It sounds like you want an option for sharp edges to have a sub-d crease, and smooth edges to not have a sub-d crease.
All of this information is available to the sub-d modeler, so it seems like this is a feature that the sub-d modeler should provide for you - "make creases on sharp poly edges".
It's better for them to do that since that way they will provide this functionality on the OBJ files imported from any application that writes them correctly.
Maybe you might get better results if you export a non-welded mesh and use your modeler's merge points function, if that has an option to automatically apply creases when it is merging points together.
275.139
Currently it's possible to click on profile/rail curves for sweeps, show points, and change their orientation, size, and shape.
I would like the same functionality for solids. Unless I missed it somewhere, it'd be nice to click on a sphere, cube, cone, cylinder, etc, and be able to adjust/tweak them after the fact.
275.140
Hi Michael!
My wishes for v3-4
Instances!!! - they should also have custom user parameters(to which we can assign parameter types) assigned to them so that we could count our assembly parts and possibly export that data out into Excel via obdc port?
Views Browser!
Communication of our design requires many many views to be exported out of model.
Main principle behind Revit success is a view browser which allow us to create/delete views (based on section planes) and place them onto a sheet which is another type of a view in the same browser
*a much more elegant solution than that of a SketchUp
Section planes!!
those actually create new views (with view depth and crop box)
Sheets!!! (see pic also)
Part of a view browser - are actually 2D views which allow us to use our custom design sheets and place formatted text (very moderately formatted) (Ability to add dimensions with various tick forms along with text is also required)
this is all for v3-4 - yet another list for v5-6 is already compiled))
Michael, I know your software is for artists mainly - and there is soft like Alibre and so on out there.. but if you implement these wishes there will be no need to use any of those anymore)))
Igor
Size: 218.4 KB, Downloaded: 64 times, Dimensions: 1600x1170px
275.141 In reply to 275.140
Hi Igor - those are great wishes, and they do actually fit in well with where I want to try and take MoI in the future.
I do generally want to add in a category of what I would call "communication" type features - things that can help you communicate your design to other people. Those kinds of functions can benefit many kinds of artists as well! That term "Artist" I tend to use rather loosely.
A bunch of things like being able to generate line drawings, do some basic dimensions and printing will kind of fit into this general "design communication" area, which I do want to explore!
It's hard to know exactly when all this will happen though, probably some bits and pieces will come together over time.
I think there is a good chance to use the scene browser as an area of UI to hold some of these things though, like you are showing there! That will probably help quite a bit since one of the major problems with adding in new stuff is trying to figure out where to place it in the UI so that it does not mess things up too much.
275.142 In reply to 275.141
Re generating line drawings
There are two approaches to how "views/sections/cameras" are represented on a sheet(communication)
1 Viewports
2 2D generation - is a problem approach in opinion of 99% of those who used both methods in actual work and cost Archicad a large decline in customer base when Revit turned up and offered method 1 (you may check out if you still have it)
SketchUp does not generate anything 2D for Layout as well - but does not offer the flexibility of Revit where you can create a view and annotate model only within confinements of that view so that it will not interfere with the rest of the model (all annotations belong to a view - not the model) and then place that view on a sheet(communication)
Another suggestion for how it all will fit into UI and not make any damage to the overall user experience - is again to use scene browser area and have possibly two modes for it (via main tabs?) - tab one: Scene, tab two: Views(Comm) which is where all sections/elevations/3dcameras will appear as views after their creation by sections or cameras - see illustration attached
or combine them without any higher level tabs (Revit case and is show in my prev mes) but after experience with such combined browser in Revit I can say that it would still be better to split the browser as it tends to collect garbage in various divisions(tabs) and user start to scroll too much
Hope you'll find this useful
Regards,
Igor
Size: 230.6 KB, Downloaded: 41 times, Dimensions: 1600x1170px
275.143 In reply to 275.142
Hi Igor, some good ideas there, thanks!
One other thing that I have thought of before would be to have an additional "Print" tab on the view layout tabs (the ones at the bottom that say Split / 3D / Top / Front / Right), which you could hit to switch the main viewport between 3D model mode or 2D print space mode.
Then when you drew anything (annotations or geometry or whatever) while in print view, those things would get added to the active sheet only and not to the regular 3D model.
Maybe the Print tab would only show up after you have initially created a sheet. But I've also thought about possibly the other way around - that the print button would be shown always and when you hit it some other UI would then also activate for setting up and manipulating sheets, but that idea was before there was a scene browser.
275.144 In reply to 275.140
Hey Igor, where did you dig this thread from ? It's like pulling out an old photo album on MoI as a baby :)
Ok, while I'm here, I wish for peace on earth...............Oh! MoI wishes.
There is one feature I do like from other modeling programs and does come in handy for repair work and that is, enlarge a surface.
In it's simplest form you pick a surface and it creates an untrimmed copy of the original surface, which would be one thing. In it's advanced form once you pick a surface, an untrimmed copy is created but then you have U and V sliders to enlarge or shrink that copied surface.
Is this possible with the geometry library MoI uses ?
275.145 In reply to 275.144
Hi Danny, yup that is possible with the geometry library tools. The bigger issue can sometimes be about setting up the UI for such things.
> one thing.
This part you can actually do right now by using the "untrim" operation in MoI. To do an untrim, select all the edges that make up a trimming boundary and hit Delete, that will remove that boundary and recover the underlying surface.
The edges must not be a joined edge between 2 surfaces though, so you may need to delete some surfaces or use Edit/Separate on any joined surfaces to break the edges you want to remove to not be connected to other things.
Also if the trim boundary touches the seam edge of a closed surface, the seam edge is part of the boundary and should be selected too.
The easiest way to remove everything is to use Edit/Separate to make the surface into a single unjoined surface, and then select one edge and then hit Ctrl+A to select all edges and then Delete.
Check out this previous post for an illustration on untrim:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
(EDIT: I just saw on another recent message that you definitely knew all about this - are you asking for something different with this extend mode than what can already be done with "untrim" / delete trim edges ?)
This one I'd need to think about the UI for a bit which may take some time... Probably it could go in the Extend command, but then when it goes there it may be good for it to have several modes like an "extend to boundary" mode like the regular curve extend.
Show messages:  1-5  …  66-85  86-105  106-125  126-145  146-157
