Punch holes
 1-4  …  25-44  45-64  65-84  85
2749.65 In reply to 2749.63
Hi Burr you're welcome, I'm glad that helped.
> THough the Pipe command will work well with the segments
> created with this command also.
Yup, and actually having those straight cylinder pipes will be much, much lighter geometry (less dense with control points, etc...) than pipes that actually tried to follow along the curved paths. So that could help a lot to keep things more manageable, things like file size and memory consumption would not bloat up as much with these as the cutting objects.
Also maybe easier for actual assembly to have the holes be straight even if they are angled, rather than actually having sort of "bending holes" ?
2749.66 In reply to 2749.65
Yes I agree. Although if I was going to bool out the cylinders, then I would have to adjust the thickness of the panels on both sides by the diameter of my cylinders before I do the construct Isect command so the pipes would actually cut a clean through hole!
I also rethunk the "Why 3d holes". A 3d Printer would be nice to have, Eh! Then you could template drill all the angle holes.
Anyway, this "slicing" has come up before and I think the couple tools you've provided here are a great addition in this area.
2749.67 In reply to 2749.64
< Is there some task in particular that you could use a method for collapsing points together for?
In case of big zoom to be sure that the curves are connected?
And for a new sort of connection
Seems different than Chamfer or extend
2749.68 In reply to 2749.67
Hi Pilou, is that something you need for a project you are currently working on?
In the future I do want to add in some additional tools for manipulating points, probably some kind of "set point location" option that will show up in the properties panel when you have control points selected.
But also currently one way to get the result you want there is to use the "Flat" snap feature of the edit frame twice in succession like this:
Does that handle what you need currently?
2749.69 In reply to 2749.68
I have no need actually, it's just for the possibilities :)
And yes i can make that you show for some points by hands :)
But for many lines computer is more friendly (with tolerance) :)
2749.70 In reply to 2749.63
To Michael, Blurr and Pilou
I am silent reading the thread because I'm better reading English then writing : )
It's hard to me to reply more consistently, with a more subtle and fluid English.
@Blurr
What I need is EXACTLY What you done. Better saying... what I supposed I need. When I'm doing my pieces things changes all the time. In other words, the process to achieve a "form" is equal or more important then the envised form. In this particular piece perhaps I'll abandon the wires and cut closed plexiglass shapes for the slices. I done something like that in the past with hand cut glass.
To finish this boring talk, is something like achieve an imbalance between the technical problems to build the piece and unleash the emergence of the form.
BTW this job will be done with a router, a french one. I don't have the machine myself. I use this router and a laser cutter as a service.
Usually I send to them 2D vector files. This is the first time that I'm trying to use a 3D tool to go a step forward, not only to sketch and better visualize something.
Another BTW: How can I export from MOI the "flatten" project to be understood by the router? Something tell me that this is a silly question : )
(My stock of words are lowering, time to brake!)
Many many thanks to all of you.
I'll keap reading (and learning)
Angelo
2749.71 In reply to 2749.70
Hi Angelo,
>>>>>BTW: How can I export from MOI the "flatten" project to be understood by the router? : )
This depends on the software your machinist has. If he has 3d Cam software, most likely you just send him the 3DM file, along with an understanding of what you want, and his software does what you need. (There are a few other export formats that MoI does that he may ask for. IGES, STEP...etc.) If he requests a format you arent sure of, post back here as there are many that can help.
The assembly of this piece seems it would need to happen at "design time" ( wires formed while inserting into plexiglass). A very cool project. Are you an artist or a scientist?
Its amazing the different methods/approaches people use (Grendels is very cool).
I have a stange feeling that MoI can do "ANYTHING".
Thanks Michael.
BTW: Angelo, you use english well.
2749.72 In reply to 2749.70
Hi Angelo,
Like Burr mentions, what format you send can vary depending on exactly what hardware/software your service is using.
Some may be able to take in a 3D CAD file, such as 3DM, IGES, or STEP, but others may expect to get a 2D illustrator file. For those ones you would get your flattened curves arranged in one of the ortho Top/Front/Right views and then use the AI format export out of MoI to save a 2D snapshot of your curves from one of those views. There is an option that pops up for AI export for which view to use.
Some programs may want to take in flattened curves in the world XY (Top) plane in DXF format. MoI does not currently have a direct export to DXF but there is a 3DM to DXF curve converter here which you can use to get curve data from MoI into DXF format.
But you'll need to ask your service which format they require.
If they are able to take a 3DM file then that would be the one to prefer.
2749.73 In reply to 2749.71
Hi Burr,
I'm a 55 years old artist. And I love some cross sections between the way new things came alive in science and in art. The way that a "invention" coagulates from given knowledge but also from an invisible stream, articulated in background. Silently.
I am assembling structures a little bit from an organic reference, but not representational, from the eighties.
Like this big piece in corten steel. This was done in a PVC model, directly cut with a jigsaw. The corten piece was build in a shipyard. Acetylene cut, an old machine with an optical "reader".
Some years after I've been cutting and reassembling some given organic objects, like a femur head. This one I saw a plaster model them I scanned the slabs and use the blend function in Illustrator to create intermediate pieces as I can't saw thin slices.
If you have interest here are some visual information: www.angelovenosa.com
Angelo
2749.74 In reply to 2749.72
Hi Burr, Hi Michael
The people that machine my pieces uses a Meca router and Laser cutter.
The proprietary Cam sofware is something like "Type3"...
The workflow they uses is Solidworks / some 2D export / Type3
I usually send 2D Illustrator files. But now, with MOI, I'm "thinking" 3D.
(I hate to delegate, I love to put my hands in all the stages of the work. But this is limiting) So... using MOI I tried to export to illustrator and after some revision send the files. I tried this on this file:
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=d7f970fda89516901d9bf1e9e21836cf&filename=plywood.3dm
And I had some minor problems.
If I export all the pieces, with the superposition of different objects, they lines will be indistinguishable. Each object was transformed in a collection of "unglued" lines. I had to export one by one. Not a big problem. But... It exports a screen shot of the 3D. I had to choose the top surface and clean the lines of the bottom surface.
(Michael don't waste you time with this file, I dismiss this project, actually I redone it)
So I decided to delegate and send the 3dm file to a young guy, full of time and energy to read the file in Solidworks and do the rest of the job. (But I think that next time I will go till the end!)
Angelo
2749.75 In reply to 2749.73
Hi Angelo, I checked out your web site, that's a lot of very cool and interesting stuff, I liked it!
2749.76 In reply to 2749.74
Hi Angleo, yes for AI export you probably won't want to write just an entire set of 3D objects to the AI file because you'll get things like duplicated curves because you'll get both front & back edges and things like that.
So you (or your young assistant...) would need to do things like select just the front edges from a slab and then use File / Export which will write just those edges to an AI file and then repeat that for each slab.
One thing that can help with that is that you could select one edge by clicking, and then use a window select to capture other edges - if you did the window select in the Top view you would be able to capture all the edges on the front side of one of those slabs with one strategic window select.
2749.77 In reply to 2749.74
Hi Angelo, Very nice work!
Your router people can receive your 3d model and manage edges as they are in 3d. It may help them to also understand your intent. But you also said your preferance is to try to do as much as you can yourself. (Not passing on the artisticc creation process :)
If you are just making the move to 3d, you may want to get on the phone with them and discuss whats best. Solidworks can import your MoI Models as-is, then that could leave them room to bring it into the CAM side more efficiently.
Good luck, thanks for sharing,
Burr
Take a look here for see what artists has made with different progs and Moi of course ;)
http://forum.jotero.com/index.php
http://forum.jotero.com/viewforum.php?f=25&sid=491b524b3ba1bd3c5cf8270f6ec27549 Gallery
EDITED: 7 Jul 2009 by PILOU
2749.79 In reply to 2749.78
Hi Pilou
One thing that came to my attention looking at these images is that although they're from different people (I assumed that...) they seems coming from the same place. They share all a common ground.
And resounds something from my father, an old italian carpenter, some vision of art as overcoming on craftmaship, Paganini art : )
(btw. these things are made with rapid prototyping?)
thanks for sharing
Angelo
EDITED: 8 Jul 2009 by ANGELO
2749.80 In reply to 2749.79
No all these images and objects are made by the same artist Torlof aka Jotero ;) First on the list of the gallery ;)
He uses different progs TopMod, 3Dsurf, Paraclouds etc...and very often Moi!
3D digital images renders, 3D printing and sometime concrete!
Amazing power of the geometry!
2749.81 In reply to 2749.80
Just to upgrade the discussion...
This is what I actually done with these bird lines:
http://www.angelovenosa.com/laura
Sorry... the page is in portuguese, but the images are self explanatory.
This link work as a container for the catalog images, for the designer and the curator follow how are the photo documentation.
Angelo
2749.82 In reply to 2749.81
Very cool Angelo!
2749.83 In reply to 2749.36
I'm trying to use this script (MoveSliceToPoint - four years after...) and seems to be broken in Moi Beta.3.
Can you help me with this?
Best regards!
Angelo
2749.84 In reply to 2749.83
Hey Angelo,
I just tried it over here and it works ok..... Can you describe whats happening for you?
Show messages:  1-4  5-24  25-44  45-64  65-84  85
