Punch holes
 1-18  19-38  39-58  59-78  79-85
Ok I see :)
You can easily have the result but with "box hole" against "cylinder hole" ;)
Replace Rectangular "Plexiglass box" by rectangular Plan
Close all curves
Select all curves lines closed, Extrude them on the longitudinal side by the measure that you want hole (so a little measure)
Select all volumes result and make a Copie /Size
Make boolean Diff between them
Make Boolean Diff Plexi Glass with result above
Extrude Plexi Glass = you have your result wanted : just Fillet if you want a more smooth result ;)
EDITED: 4 Jul 2009 by PILOU
2749.20 In reply to 2749.19
Hi Pilou, sorry that previous image I showed was simplified to get the idea across.
If I understand correctly, the other problem is that some pieces will be coming in to the slab at an angle, like this for example:
So it is desired to have an angled hole for those cases, like this:
That seems to be what Angelo was looking for.
2749.21 In reply to 2749.20
aaaah new difficulties :)
All depend in what material are the links!
If it's rope it's not necessary to have your forms :)
And my method works
if not my method don't works :)
Some infos are necessary :)
PS My method above works also just don't replace at the beginning the Plexiglass by a plan but keep it :)
Of course holes wille be as the Boolean Diff will give the result so maybe little complex holes :)
2749.22 In reply to 2749.18
Hi Michael.
>Were you looking for a distribute function as way to arrange parallel planar objects?
Yes, if I have around 15-20 objects this could be achieved with Array plus some snap to object
but with more then hundred objects a distribute function could be a must.
Angelo
2749.23 In reply to 2749.22
Also it seems as though all the curves are slightly rotated about the Z axis. It makes many things difficult. I wonder if a cplane could work for this?
2749.24 In reply to 2749.21
Hi Pilou, thank you for all the strugle.
I attached some photos from old pieces only to show how I've been working with "slices".
This skull from 1996 was made with iron wire glued over glass slices, the MOI piece will be constructed also with wire but with 160 planes and not 11 as this one. If I use glass planes as support the transparency disappears, 160 slices would be a green opaque block of glass. So... I think of "sew" the wires trough plexiglass planes, these planes will be drilled on a router with the drawing that I'm trying to produce with the help of MOI. (this was the worst English phrase of the day!)
Another piece uses glass panels with salt stain (actually crystalized salted water).
And there is a self-portrait made of MDF cuts.
Thank you for now (time to sleep).
2749.25 In reply to 2749.23
In fact this is a kind of error, I think the model inherited some misplacement when the MRI was done.
How do you think the cplane could help?
2749.26 In reply to 2749.22
Hi Angelo, re: distribute to arrange parallel planar objects
Do you also mean having a initial starting position with all those objects in one single plane?
If so, then I don't really know how I could accomplish that very easily, since there would not be any really straightforward method for a piece of code to automatically recognize how to assign an ordering to all those pieces.
It would probably take some kind of sophisticated artificial intelligence or pattern recognition or something along those lines...
2749.27 In reply to 2749.25
Well, the misalignment was giving the things I was trying problems which is why I started suggesting other methods.
It appears that the misalignment may be "Uniform" or universal. (As you said from the original model.
If the "rotation" could be determined then you could add a new Cplane that would make all the geometry "perpendicular" and methods like extrude would work better.
I tried to do some trims of the curves to follow up with my thought, but MoI balked. I WAS on my wifes lessor power computer at the time and I could try to do smaller sections at a time.
I like what your doing and will follow up more to see if my solution could be viable. For me it would be, "What takes longer?" redoing the geometry you have to accomplish your setup, or breaking the curves with a couple horizontal planes and using those pieces to identify the points, then a second set of full wires to assemble.
Can you make the MRI available here?
@ Angelo
If your material is metal cord my method above will work !
(no need to have perfect orientation inside Plexiglass rectangular, cylindric as shown by Michael or any forms )
filled rectangular holes for example
I am just curious how you can place these wires without deformation inside the plexiglass :)
Ps Your original on top view is not exactly fit to the grid, (// & Perpendicular) is that normal?
Another method more easy and keeping the orientation of wires inside the plexiglass!
Seems that is a valid solution ;)
And you can move all lines in one one move!
EDITED: 5 Jul 2009 by PILOU
2749.30 In reply to 2749.28
A possible solution would be to wind Pianowire(Springwire)
around a Pianowire and then shape it the way you want.
Size: 16.8 KB, Downloaded: 122 times, Dimensions: 587x403px
2749.31 In reply to 2749.26
>Do you also mean having a initial starting position with all those objects in one single plane?.
Not exactly, I mean objects in different parallel planes uneven spaced.
And then you could distribute by center or entering some value for spacing.
Angelo
2749.32
Hi folks,
Project a little bit suspended. I'm doing some physical work by now...
Cutting and assembling wood.
I think that I will rework the proposition, not by the problems found when drawing but because there are some bad formulated esthetical questions (bad English...)
Angelo
2749.33 In reply to 2749.31
Hi Angelo,
In that case, for the situation where you were concerned about possibly having hundreds of objects, you would still need to ensure that each one of those objects was placed at a unique location separate from all the others.
Since you have to move each object anyway, you can create some point markers beforehand at the proper distances, and just place each object in its correct position right when you first move it. I think that would actually help to ensure that you've got each slice in a unique location too.
Here's the way that would work - say you have these slices:
Create a point object (Draw curve / More / Point) in that plane:
Replicate the point object using Transform / Array / Dir, for the second point you can enter in a distance constraint by clicking in the "d" field in the bottom toolbar (beneath the XYZ input and to the right of the view tabs) to control the distance between each of the points:
Then to place a slice, select it:
And then run Transform/Move. For the base point, pick the original point, or if it is located at 0,0,0 you can type in 0 <enter> for the first point:
For the offset point, pick the target marker:
That will help to ensure each slice is separate, and also place it into its correct position all at the same time. To repeat, you adjust the selection after you finish one Move, and then use Right-click inside of a viewport to repeat the Move command.
Also it may not be a bad idea to delete the target point you just used, so that you know that the last one is always the new target.
Later on if you want to adjust the spacing, that is possible using the Transform / Scale / Scale1D command.
Go to a side view, and pick the base point of the scale to be at the base point location, pick the first reference point of the scale to be on the first section, and then the final reference point of the scale will adjust the spacing for you, like this:
That works because Scale1D only alters things along one direction. If that direction is normal to a planar object's plane then it will have this effect of moving the object by a scale factor towards or away from the scale origin.
I hope that helps!
2749.34
Here is one way to quickly automate the bores for your wire to pass through the plates. You will need the plugin mentioned in this thread: http://moi3d.com/forum/messages.php?webtag=MOI&msg=2755.1
1- draw a straight line on center of your skull profiles to trim them in half. I noticed your profiles are not symetrical but it is close enough.
2- This will make a 2d point cloud for you to use the copy to points script mentioned above.
3- delete half of your skul profile for easy selection later.
4-5 add a cylinder on center with a large enough diameter for your wires to pass through. These will be the holes you will be punching through the dividers.
6-7 select all your profiles and turn on "show points" and then select all the points on the centerline and copy and paste them.
8- select all your profile lines and then hide them. Now you see the point locations on your plane.
9- run the "copytopoints" script selecting the cylinder and the points and it will replicate the cylinders on all the points.
10-11 You now end up with this result and you start booleans to remove the cylinders from the plate leaving result 11.
I hope this helps. This is kind of similar to kids putting lots of nails in boards and wrapping different color string around them to make geometric patterns.
EDITED: 6 Jul 2009 by GRENDEL
So some solutions :)
PS @Angelo: Nice site's Gallery!
2749.36 In reply to 2749.1
Hi Angelo, it occured to me this morning that this process of moving slices into their precise target location can be mostly automated pretty easily.
I've attached a custom plug-in command here called MoveSliceToPoint.js which can be used for this.
To install it, download it and copy it into the \commands sub-folder inside of the MoI 2.0 beta's main installation folder (it may also work with v1, I have not tested it there though). Then set up a keyboard shortcut and for the command put in: MoveSliceToPoint
Now when you activate that keyboard shortcut it will launch the command.
This command expects a setup of point objects like this:
You can draw a point object using Draw curve / More / Point, and then make a duplicate of it at your desired spacing using Transform / Array / Dir, use a distance constraint by using the "d" field in the bottom toolbar to control the spacing for the array.
It assumes that the point object closest to 0,0,0 is the starting point that is on the plane of the objects, and the point object furthest from 0,0,0 is the target point.
To use the command, select the outermost curve (the one that should be moved to the end), like this:
And then press the keyboard shortcut to launch the command. It will move the selected object to the furthest target point, and then remove that target point:
So because that target point was removed, now it is all set up to select the next curve and repeat the command by a right-click to move it into place, and so forth. So you can rapidly move a bunch of slices into place with this method by just by repeated select + right click, select + right click, etc...
This should help to greatly speed up the arrangement of slices like this, here is a screencap of it in action:
I hope this may help out the next time you have to arrange a large number of slices like this.
EDITED: 6 Jul 2009 by MICHAEL GIBSON
2749.37 In reply to 2749.36
Does it possible to have a script who make that?
of course curves lines given beeing as on your drawing in order of size ;)
In sketchup i have made a script (my first ruby script with some helps :) who can make that :)
http://forums.sketchucation.com/viewtopic.php?f=180&t=20313&start=0&st=0&sk=t&sd=a
EDITED: 6 Jul 2009 by PILOU
2749.38 In reply to 2749.37
If this is going to be done with automation then it is not a 3d operation. It would be done in 2d. Getting a "point" where the wire intersects each side of the plexiglass would be what is required. One point = Drill. Where there is a diaganol cut, the 2 points for each side would be connected then the "slot" would be created with a profile cut. If this was my stategy, I would ask if there was a script to connect 2 points with a line to speed this part of the process up. So in summary:
Can the Isect command place a point where the wire enters and exits the solid?
Can I automatically connect 2 points?
These along with the previous "spacing script" Michael made would create this part "as is".
I would then bring that file into my cam package and drill all points, then profile cut all the line entities.
Show messages:  1-18  19-38  39-58  59-78  79-85
