Punch holes
 1-12  13-32  33-52  53-72  73-85
2749.13 In reply to 2749.11
> Such fonction don't exist? Maybe must be add to the Array Transform?
No, there's not any function for what you are showing there.
That's basically a 2-rail sweep.
In the future here at some point I'll have an "extract isoparm" command which would make it possible to build a 2-rail sweep surface and then extract some curves from that surface.
That will probably be the way to achieve that in the future.
But I don't believe what you are showing there is related to Angelo's problem though.
2749.14 In reply to 2749.12
> PS With the Browser does it possible to select only open
> curves (after the planar automatic function)
No, not currently. I do have some ideas for making additional kinds
of "filters" to allow for things like that.
But it is possible to select all open curves by use of a keyboard shortcut
script, put the following on a shortcut key for that:
script:var curves = moi.geometryDatabase.getObjects().getCurves(); for ( var i = 0; i < curves.length; ++i ) if ( !curves.item(i).isClosed ) curves.item(i).selected = true;
> And there is not inverse selection inside the Browser? (Because I
> have found how see only the surface :)
It's possible to deselect the objects for a browser item by holding
down Ctrl and clicking on the browser item's text.
Also right-clicking on a browser item's text will do an
"isolate selection", where that item becomes the only selected
item and everything else is deselected. This can be useful if you
want to set one item as the only selected object with a single click.
2749.15 In reply to 2749.13
< But I don't believe what you are showing there is related to Angelo's problem though.
If a "multi sweep array"(?) exist it will very easy to have the all quadrangular mesh with the parallel curves given
Then make some intersections after with the Plexi rectangles
But i don't visualize what must be the final result :)
2749.16 In reply to 2749.15
> If a "multi sweep"(?) exist it will very easy to have the all
Sorry, I don't understand this one...
If you want to do a "multi-sweep" as a method of creating a surface, you can use the Network command for that kind of thing, it allows for a crossing network of curves and is not limited to only 1 or 2 rails like sweep is.
But if you are talking about replicating curves across an area, I don't think that will help for this particular case. As far as I understand the problem, Angelo is trying to create holes similar to this:
But instead of straight holes, the hole should actually follow the contour and angle of the wire. So to do that surfaces must be created to intersect with the slabs.
2749.17 In reply to 2749.1
I was wondering if you had considered this type of plane layout?
since you know the spacing, you could put a temporary grid on the plexy then use MoI to cut your curves down the middle and place each side seperatly. It didnt sound like you were going to automate the task of drilling?
There would be a couple smaller inner horizontal planes to accomodate the upper and lower pieces but seems like it would work. Trying to visualize though.
2749.18 In reply to 2749.10
Hi Angelo, it's always fun for me to see interesting things being done with MoI!
> About distribute: I was doing exactly what you suggested
> but sometimes (when you have a big bunch of objects) a
> distribute command could be easier. I think this is uncommon
> in the CAD area, more related to 2D vector drawing apps.
Yeah, this is not commonly found in CAD programs.
But I do like to have elements from 2D vector apps combined into MoI as well, and I have been gradually adding some things from that area into MoI over time.
One pretty big one for MoI v2 was the inclusion of a bounding edit frame so that you could quickly scale or rotate objects by grabbing grips on the bounding box around the selected objects, similar to how 2D vector drawing apps work.
Some kinds of 2D vector operations can be more difficult to fit in to function with 3D objects though, and also it can be difficult to add in the element of accurate placement which is usually a focus for MoI.
Were you looking for a distribute function as way to arrange parallel planar objects?
Ok I see :)
You can easily have the result but with "box hole" against "cylinder hole" ;)
Replace Rectangular "Plexiglass box" by rectangular Plan
Close all curves
Select all curves lines closed, Extrude them on the longitudinal side by the measure that you want hole (so a little measure)
Select all volumes result and make a Copie /Size
Make boolean Diff between them
Make Boolean Diff Plexi Glass with result above
Extrude Plexi Glass = you have your result wanted : just Fillet if you want a more smooth result ;)
EDITED: 4 Jul 2009 by PILOU
2749.20 In reply to 2749.19
Hi Pilou, sorry that previous image I showed was simplified to get the idea across.
If I understand correctly, the other problem is that some pieces will be coming in to the slab at an angle, like this for example:
So it is desired to have an angled hole for those cases, like this:
That seems to be what Angelo was looking for.
2749.21 In reply to 2749.20
aaaah new difficulties :)
All depend in what material are the links!
If it's rope it's not necessary to have your forms :)
And my method works
if not my method don't works :)
Some infos are necessary :)
PS My method above works also just don't replace at the beginning the Plexiglass by a plan but keep it :)
Of course holes wille be as the Boolean Diff will give the result so maybe little complex holes :)
2749.22 In reply to 2749.18
Hi Michael.
Yes, if I have around 15-20 objects this could be achieved with Array plus some snap to object
but with more then hundred objects a distribute function could be a must.
Angelo
2749.23 In reply to 2749.22
Also it seems as though all the curves are slightly rotated about the Z axis. It makes many things difficult. I wonder if a cplane could work for this?
2749.24 In reply to 2749.21
Hi Pilou, thank you for all the strugle.
I attached some photos from old pieces only to show how I've been working with "slices".
This skull from 1996 was made with iron wire glued over glass slices, the MOI piece will be constructed also with wire but with 160 planes and not 11 as this one. If I use glass planes as support the transparency disappears, 160 slices would be a green opaque block of glass. So... I think of "sew" the wires trough plexiglass planes, these planes will be drilled on a router with the drawing that I'm trying to produce with the help of MOI. (this was the worst English phrase of the day!)
Another piece uses glass panels with salt stain (actually crystalized salted water).
And there is a self-portrait made of MDF cuts.
Thank you for now (time to sleep).
2749.25 In reply to 2749.23
In fact this is a kind of error, I think the model inherited some misplacement when the MRI was done.
How do you think the cplane could help?
2749.26 In reply to 2749.22
Hi Angelo, re: distribute to arrange parallel planar objects
Do you also mean having a initial starting position with all those objects in one single plane?
If so, then I don't really know how I could accomplish that very easily, since there would not be any really straightforward method for a piece of code to automatically recognize how to assign an ordering to all those pieces.
It would probably take some kind of sophisticated artificial intelligence or pattern recognition or something along those lines...
2749.27 In reply to 2749.25
Well, the misalignment was giving the things I was trying problems which is why I started suggesting other methods.
It appears that the misalignment may be "Uniform" or universal. (As you said from the original model.
If the "rotation" could be determined then you could add a new Cplane that would make all the geometry "perpendicular" and methods like extrude would work better.
I tried to do some trims of the curves to follow up with my thought, but MoI balked. I WAS on my wifes lessor power computer at the time and I could try to do smaller sections at a time.
I like what your doing and will follow up more to see if my solution could be viable. For me it would be, "What takes longer?" redoing the geometry you have to accomplish your setup, or breaking the curves with a couple horizontal planes and using those pieces to identify the points, then a second set of full wires to assemble.
Can you make the MRI available here?
@ Angelo
If your material is metal cord my method above will work !
(no need to have perfect orientation inside Plexiglass rectangular, cylindric as shown by Michael or any forms )
filled rectangular holes for example
I am just curious how you can place these wires without deformation inside the plexiglass :)
Ps Your original on top view is not exactly fit to the grid, (// & Perpendicular) is that normal?
Another method more easy and keeping the orientation of wires inside the plexiglass!
Seems that is a valid solution ;)
And you can move all lines in one one move!
EDITED: 5 Jul 2009 by PILOU
2749.30 In reply to 2749.28
A possible solution would be to wind Pianowire(Springwire)
around a Pianowire and then shape it the way you want.
Size: 16.8 KB, Downloaded: 122 times, Dimensions: 587x403px
2749.31 In reply to 2749.26
>Do you also mean having a initial starting position with all those objects in one single plane?.
Not exactly, I mean objects in different parallel planes uneven spaced.
And then you could distribute by center or entering some value for spacing.
Angelo
2749.32
Hi folks,
Project a little bit suspended. I'm doing some physical work by now...
Cutting and assembling wood.
I think that I will rework the proposition, not by the problems found when drawing but because there are some bad formulated esthetical questions (bad English...)
Angelo
Show messages:  1-12  13-32  33-52  53-72  73-85
