Conic curves and surface
 1-12  13-23
2746.13 In reply to 2746.12
I was thinking that knowing the value of the one you "create" could then lead to addition of others with some kind of progressive formula.
I may not understand what this value is and how its used. I was assuming it had something to do with the curvature of the segment and that if I used .01, .05, and .1 it would give me some kind of natural progression between 3 curves.
2746.14 In reply to 2746.13
Hi Burr, actually it does work like that so you may like to use the value in that way.
For example here is one with Rho = 0.5 :
And here Rho = 0.6 :
And here Rho = 0.8 :
As the value moves towards 0 it becomes flatter, here is Rho = 0.01 :
The category of conic section is also related to the Rho value.
With Rho = 0.5, the curve is a segment of a parabola.
With Rho > 0.5 and < 1, the curve is a segment of a hyperbola.
With Rho < 0.5, the curve is a segment of an ellipse.
2746.15 In reply to 2746.14
Is this going to be a keyboard shortcut or are you adding it to the Draw curve icon set ?
2746.16 In reply to 2746.15
Hi Danny,
I think I'm going to add it under Draw curve > More > Conic , beside Helix.
2746.17
Excellent, Michael, great addition to MoI!
-Will
2746.18 In reply to 2746.15
Here's where the new conic command will live in the UI:
2746.19 In reply to 2746.18
Just stay now one place free here or can you have more levels possible? :)
2746.20 In reply to 2746.19
Hi Pilou, I generally try pretty hard to figure out other possible ways to add functions without adding too many icons...
But in the future it will be possible for me to add more than one additional item there. It will wrap and expand to take up multiple lines if necessary, like this:
2746.21 In reply to 2746.20
Saved :)
2746.22
very nice addition :)
2746.23
Hi Michael
Great you could get this done so quickly. Looking forward to the next beta to try it out.
I like the interaction shown the tan/tan snap. I understand the command creates a curve object so the rho value is not editable after creation. Will be nice when this type of history is built in.
Jamie
Show messages:  1-12  13-23
