Shortcuts Problem V2
All  1-4  5-10
2714.5 In reply to 2714.3
Hi Brian, I just posted the script copier utility function here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2711.16
If you run that, it should copy the script files that your shortcuts are trying to use over to the new beta's folder.
After you run it, your keyboard shortcuts that were hooked up to those scripts should then work in the new beta.
2714.6 In reply to 2714.5
Thanks Michael.
Does the attached help in explaining a potential future approach ?
Brian
Size: 94 KB, Downloaded: 71 times, Dimensions: 287x1199px
2714.7 In reply to 2714.6
Does this--stage 2--- help to tell the "New Users Understanding Problems"?
Hope of value
Brian
Size: 240.7 KB, Downloaded: 69 times, Dimensions: 953x936px
2714.8 In reply to 2714.6
Yup, that idea is clear.
Hopefully in the future sometime I will be able to find the time to work on that.
It's hard to know exactly when though - it will probably take a while.
Unfortunately I just do not have a whole lot of time available to me, there are also a lot of other things that I am working on.
2714.9 In reply to 2714.7
Actually, I don't quite follow you on this part though - what you are showing there are a bunch of customized keyboard shortcuts that you have added in yourself.
New users don't see the same list that you show there.
But yes, in the future it would be nice to make improvements to the shortcut key mechanism though, right now it is definitely pretty bare bones. Usually most people don't spend a whole lot of time in that part of the program UI though.
2714.10 In reply to 2714.9
Yes, I would think so also.
Bit crazy that when you try to find/use a short cut you can't understand what it's supposed to do---which one does what?.
Brian
Show messages: All  1-4  5-10
