Shortcuts Problem V2
All  1-3  4-10
2714.4 In reply to 2714.3
Hi Brian, well we've been over this seems like a dozen times before....
I really wish that I could produce a nice shortcut key editor for you, but it takes a lot of time and effort to do that.
Right now there are just too many other things like bug fixes, improvements to file exports, etc... which are currently a higher priority.
If I spent a month working on a wonderful shortcut key editor, it would mean a month of not working on these other higher priority areas. That is just simply not feasible for me to do right now, sorry!
> I don't have to go down this path with any other app and
> the time/complexity---I have better things to do.
I can certainly understand if MoI is not a good fit for you - it sounds like you would probably be better off using those other apps and staying away from MoI.
2714.5 In reply to 2714.3
Hi Brian, I just posted the script copier utility function here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2711.16
If you run that, it should copy the script files that your shortcuts are trying to use over to the new beta's folder.
After you run it, your keyboard shortcuts that were hooked up to those scripts should then work in the new beta.
2714.6 In reply to 2714.5
Thanks Michael.
Does the attached help in explaining a potential future approach ?
Brian
Size: 94 KB, Downloaded: 71 times, Dimensions: 287x1199px
2714.7 In reply to 2714.6
Does this--stage 2--- help to tell the "New Users Understanding Problems"?
Hope of value
Brian
Size: 240.7 KB, Downloaded: 69 times, Dimensions: 953x936px
2714.8 In reply to 2714.6
Yup, that idea is clear.
Hopefully in the future sometime I will be able to find the time to work on that.
It's hard to know exactly when though - it will probably take a while.
Unfortunately I just do not have a whole lot of time available to me, there are also a lot of other things that I am working on.
2714.9 In reply to 2714.7
Actually, I don't quite follow you on this part though - what you are showing there are a bunch of customized keyboard shortcuts that you have added in yourself.
New users don't see the same list that you show there.
But yes, in the future it would be nice to make improvements to the shortcut key mechanism though, right now it is definitely pretty bare bones. Usually most people don't spend a whole lot of time in that part of the program UI though.
2714.10 In reply to 2714.9
Yes, I would think so also.
Bit crazy that when you try to find/use a short cut you can't understand what it's supposed to do---which one does what?.
Brian
Show messages: All  1-3  4-10
