Wavefront OBJ export/import into Kerkythea
All  1-3  4-5
2713.4 In reply to 2713.3
Hi Michael T, yes so then the idea is that with the last beta you can set up styles in MoI however you want to have materials work in Kerkythea.
So for example, if you want 5 different objects to all render with the same appearance in Kerkythea, you can assign those 5 to all have a particular style, then they will be ready to be used in Kerkythea without needing to do extra organizing work on them inside of there.
But if you have not assigned any styles to your objects, they will all have Style=Default and then all have the same appearance in Kerkythea.
This should be generally easier to manage, but maybe I had better include some option to make it possible to still get the old export behavior.
2713.5 In reply to 2713.4
Hi Michael G.,
Yes it is more manageable. It also exports the style color to the objects imported into Kerkythea. Very Cool.
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
Show messages: All  1-3  4-5
