V2 beta Jun-23-2009 available now
 1-5  6-25  26-44
2711.26 In reply to 2711.25
Hi Marc,
> I've noticed that if you subtract from an object of a
> different style, the object will have that different style
> in the new face(s) generated.
Yup, that's actually a feature that took quite a bit of work to achieve! :)
In that case, the faces that are created are not really completely new, they come from trimming faces of the operands.
Anytime that there is this kind of ancestor relationship where the face can be traced back to its source, the style of the ancestor face is maintained.
The reason why that is good is it allows for things like this - here I have a little knob that I want to array and cut out of a larger piece:
If I know in advance that I want the knob cutouts to have a different render material than the slab body, then I can at this point before the boolean assign the knob to have a particular style of "Knob" or whatever, and then after I do the array that style will replicate to the copies, and then after I do the boolean with the arrayed pieces the style will again be maintained on the fragments of the knobs.
So now there is not any further work to be done for assigning styles to all those little bits - because the styles propogated through the various operations including booleans, just setting up the one style initially let me avoid having to try to do it later to all the numerous little fragments.
Anyway, that's why it is set up with that method.
This is a bit of an unusual function for CAD modelers, many CAD systems are often more rigidly limited to only allow a single style for an entire solid and not have the ability to have different styles for individual faces of a solid. So it may be kind of different from what you are used to because of that.
I've thought about making some option that you could set to change how this worked and impose a "one style for final result" limit on the booleans though. I'll take a look at adding that in for the next beta.
2711.27 In reply to 2711.26
Objectives lens targets revealed :)
Fog is disappearing bit by bit for me :)
2711.28 In reply to 2711.23
Congrats on another great Beta.
This new feature of "Align to Surface" will be a big winner with those using MoI for jewellery designs.
The laying out of stones onto a rings curved surface was always one of those jobs I'd dread.
Looking forward to trying this out & seeing how it all goes.
regards Colin
2711.29 In reply to 2711.28
Hi Colin, thanks!
Yes, I was hoping that the Align to Surface function would help out with jewelry stuff, I have heard from people before that they needed that function.
The only trick with it is that you will need to make the initial starting object to be positioned to be aligned with the surface normal. Then with this new option the replicated copies will all be aligned to the normal at each of their locations.
2711.30 In reply to 2711.26
Hi Michael, this makes much sense and is indeed quite handy!!
Recently I didn't do much rendering stuff, just line data from solids so I guess it's more 'cad' oriented
What's tricky is that I do not realize it right away, some parts are just left floating when I try to hide styles later on.
I guess I just have to remember to sort colors before doing boole laundry!
Maybe a inline operation ticker or an choice in the options panel would be nice. (The .Ini file would be a bit deep to switch)
Marc
2711.31 In reply to 2711.30
Hi Marc, I had been thinking of an .ini switch for that since it seems like something you would want to set once and then leave it that way (if that was how you expected booleans to generally work with styles) rather than something you would be switching on and off again all the time.
2711.32 In reply to 2711.31
You're probably right, a .ini switch would do the trick. I imagine It would not change that much in work situation.
I would have imagined it as a special condition, like: 'ok this time I want to use the 'apply style' on this operation'.
This is a great feature but for the kind of work I do those days, it would be an exception for me.
No big deal there, just small workflow details.
Sometime l wish other software were written in the spirit you handle this project!
I just think of photoshop's 1.2gb installer and I don't feel well.
Moi is really one of the great computing experience I've had.
Thanks!
Marc
EDITED: 26 Jun 2009 by TELLIER
2711.33 In reply to 2711.32
Hi Marc, I'll try to think about that a little bit more.
I was thinking of possibly doing this option specifically for the booleans, but there are also other situations that can result in a multi-style solid like Join... So maybe it should be a more general kind of option that affects all solids that are created.
Also another way to get a multi-style solid is to just select one face out of the solid and set its style to something else. I don't think that I will try to disallow this one though.
2711.34 In reply to 2711.33
Hi Michael, like I've said it's no big deal and it may not be worth it if a lot of work is involved.
Marc
2711.35
Just noticed that the options pallet for export of OBJ now has a scale factor! Is that new to the Jun-23 beta or have I just been sleeping!
No need to keep swapping out my units! SWEET!
-AW
2711.36 In reply to 2711.35
Hi AW - actually that OBJ scale factor option has been in there since MoI version 1.
I'm glad that it will be useful!
2711.37 In reply to 2711.36
What on earth have been doing - sheesh! Deduct 10 points for not paying attention...here I was changing units every time I got ready to export!
Sheesh!
So far so good with the latest beta (not sure that carries any weight with my latest observation), and as always Michael great job!
2711.38
Can PointObjects have a styles color as well next time?
2711.39 In reply to 2711.38
Hi Paolo,
I'll see what I can do about that.
2711.40 In reply to 2711.1
Just realised that there is a new beta. Great stuff. Will be downloading tonight.
Just wondering, has there been any progress implementing groups?
Mark
2711.41 In reply to 2711.40
Hi Mark,
No, not quite yet - still have a couple of the very last details relating to styles in progress first.
2711.42 In reply to 2711.41
Is groups something that will make it into V2 final Michael?
Mark
2711.43 In reply to 2711.42
Hi Mark, I'm not quite 100% sure about that but I'm going to try.
If it ends up taking too long it may need to get postponed until v3 but I won't really know that until I dig into it some.
2711.44 In reply to 2711.43
I really hope you can get groups in V2 - that is one of the things that is really needed for complex model organisation. To be honest, in some ways, I would rather have groups than colours.
Even simple groups, if you can't get all the bells and whistles done in time, would be great.
Tony
(aka HamSoles)
Show messages:  1-5  6-25  26-44
