seperate a seam edge
All  1-5  6-7
2702.6 In reply to 2702.1
Hi Burr,
The only problem I see with this is, how are you going to unwrap the cylinder accurately.
When you try and move the points defining the edge, you can stretch the surface to as long as you want.
What are you trying to achieve ? Just curious :)
2702.7 In reply to 2702.6
Hi Danny,
I've been fooling around with point editing on primitives. I wanted to be able to do a bit of stretching of things and then be able to open up the seam and then use the blend tool. :O If I could open that edge by pulling a couple points, then use blend to re-close it, would be easier/faster than trying to make the cut in the surface myself. (also since the seam is a famous stickler point, utilizing it this way would be beneficial)
It just isnt the type of entity I thought it was.
Show messages: All  1-5  6-7
