Fonction "composant" - Pierrearchi
All  1-3  4-5
270.4 In reply to 270.3
merci Pilou pour ces precisions ... Possible de demander l'outil instanciation à Michael ?? ou trop tot ... pourtant une fonction importante ....
A+,
Pierre.
270.5 In reply to 270.4
Pas la peine c'est sur son carnet de doléances :)
<<I'm not really sure yet when MoI will have instances and blocks and particularly xrefs are probably even further out than a basic instance mechanism.
MoI is much more focused on being a drawing-ish tool, and just in general those features are somewhat more oriented towards assembling some large repeated pattern or assembly. It's a bit different kind of a thing than "drawing a shape".
If your current project needs such a large repetition in it, you probably are best off using some other program like Rhino to do that particular project instead of trying to do that one in MoI.
Eventually I do expect to have an instancing mechanism but I don't want to rush into it and end up forever locked into a possibly kind of antiquated system. So it's going to require quite a bit of planning to get it done, and things that require a lot of planning and design work are difficult to know when I will be able to get them done
Show messages: All  1-3  4-5
