Flyout
All  1-4  5-6
2699.5 In reply to 2699.4
I did some very simple tests with Carrara and Hypershot. I only used the styles and it was very nice. I didnt try "names" but that is good news. I know Carrara uses the "mesh grouping" you mentioned on import and this will eliminate all the extra "re-structuring" that was required. Modo must be the same.
Seems bugless as usual. May postpone the seperateobj funeral to visit with my new friend obj export.
I'll look forward to the release notes.
2699.6 In reply to 2699.5
Hi Burr,
> that was required.
Yeah, if you are focused on just wanting render materials set up you probably won't need to mess with naming things. That's just if you want to control the object structure.
Previously you would only get automatically generated names in the OBJ export like "object1", "object2", etc... which you will still get on things where you did not set the name, but now there is a way to control that by setting the name in MoI if you want.
Great! :) So far so good anyway... Please let me know if you see anything out of the ordinary.
It looks like I won't have the notes ready until tomorrow sometime.
Show messages: All  1-4  5-6
