OT - Modo 401 in two days.
 1  2-21  22-25
2693.2 In reply to 2693.1
Me too - really looking forward to 401, ZB4, and MoI 2
A good year for updates :-)
Tony
(aka HamSoles)
2693.3 In reply to 2693.1
Hello,
Let me know if they have made scene setup improvements to 401. I have been holding off on upgrading because it has been a bit of a pain for me to setup quick renders and have them look decent. Thanks.
EDITED: 16 Jun 2009 by OSTEXO
2693.4
Yes
Best to preorder it now while it is $295. After it gets released in two days it will be $395 to upgrade.
~Kevin~
2693.5
OSTexo- Modo now has a preset system similar to Hypershot that they developed and put out with Solidworks called Photoview 360. Very simple and comes with a bunch of materials and studio set-ups. I have been using it with Solidworks at work and have also been waiting for it in Modo because I don't like their scene and material system either.
2693.6 In reply to 2693.5
2693.7 In reply to 2693.6
Hello,
Thanks for the info. I went ahead and did the preorder, hoping the presets will work well for me.
2693.8 In reply to 2693.4
You can save a few bucks more through safe harbor... I bought there yesterday and I think it was $20 less.
R
2693.9 In reply to 2693.8
Finally pre-ordered it ... I'm affraid all the vertex map problems won't be fixed :'(
Anyway, looks like a cool release !
2693.10 In reply to 2693.9
you are a collector :)
2693.11 In reply to 2693.10
Still have to buy rhino, heurm ... tspline ... fryrender ... .. .
(Modo401 is out !)
2693.12 In reply to 2693.11
Moi + Modo replicator = FUN :)
EDITED: 3 Feb 2010 by PAQ
2693.13 In reply to 2693.12
Wow, Greeble-ific !!
2693.14 In reply to 2693.12
Hi PaQ,
You have been a busy boy, Awesome!
Computer = make more complete density :)
@ PaQ Seems Kerkythea has same sort of thing ;)
EDITED: 21 Jun 2009 by PILOU
2693.16 In reply to 2693.15
401 is pretty cool - love the new profile stuff.
Tony
(aka HamSoles)
2693.17
Now it doesn't get much better than that! - great work, PaQ!
Makes me sorta wish I had joined on the Modo bandwagon. :-P
-Will
2693.18 In reply to 2693.3
The new version is really great for this. I just got MoI this week-end (after getting my modo 401 upgrade on Friday), and I've been having a blast creating "doodles" in MoI while I learn the tool set, exporting them into Modo, then setting up a quick test render. I think I did a total of seven complete "scenes" yesterday. One of the things I did is create a separate custom stand-alone window/layout in modo containing just a preview view and the preset browser view. Then I can quickly import a new MoI model and set up a test scene just by dragging and dropping materials and environments right from the presets into the preview. Slick! This works really well with MoI 2.0's new ability to create surface groups...
Dave Morrill
2693.19 In reply to 2693.18
Hello Dave,
I've been tinkering with it as well but am having problems with the drag and drop materials. For some reason when I import separate meshes from MoI into 401 and try to do the drag and drop materials it doesn't work past two materials and begins assigning materials to different objects incorrectly. I also have a weird frozen noise problem that occasionally happens in the preview render window. If I could get the materials assigned correctly it would be perfect since I have no problem setting the environment and quickly rendering some good looking images (for an amateur that is).
2693.20 In reply to 2693.19
Hi OSTexo -
If you can possibly narrow this down to a small example file, could you please post the Modo file so that another Modo user could check it out?
Maybe they can then give you a tip on how it is supposed to work in Modo, or if they can reproduce the problem that could help to verify if it is a bug in Modo or something like that.
2693.21 In reply to 2693.19
I'm no expert on MoI yet, but let me tell you how I set up the MoI file that seemed to work fine when imported into modo as far as assigning materials goes:
- In MoI, I would select one or more objects that I wanted to assign the same material to, then click on a color swatch in the "Styles" palette (say Green).
- Then I would click on the "unnamed" item in the properties sheet in the top right hand corner of the MoI window and enter a name for the items in the pop-up dialog that appears (e.g. "foo").
- Then I would export a .obj file (e.g. "MoI_test.obj") and import it into modo.
When I imported the .obj into modo, I observed the following:
- In the modo "Items" list, there would be a group with the same name as the .obj file I imported (i.e. ""MoI_test").
- Inside the group would be a modo mesh with the name "foo" containing the set of MoI objects I had called "foo".
- In the "Shader Tree" tab, there would be a material called "Green", corresponding to the MoI "style" I had assigned to the items.
My guess is that you did not assign your MoI objects a MoI "style", which means they probably all ended up using the default modo Shader Tree material. So all the drag and drop stuff you did in modo was probably just replacing the same material over and over. Just a guess though.
Hope that helps...
Dave Morrill
Show messages:  1  2-21  22-25
