OT Monitors
All  1-10  11-19
2674.11 In reply to 2674.10
I think we're talking apples and oranges. But 10,000:1 means for every inch of screen there is 10,000 little points of light to use. This is the resolution capability of the screen. Massive.
If you look at the dimensions of the panel in relation to the number(900) and compared to a 30 inch with "2560 x 1600 " there is no difference. It's just the native relation to have an image appear normal. If you shrink the 2880 number down, the 900 could go up! Contrary to popular belief, the 1024x768 is NOT resolution. It is SIZE. In an image, an 800x600 image does not denote the resolution. The DPI does. If you change the "600" to something, the image just stretches. Same thing with the monitor.
2674.12
hmmm not sure about your theory there..... but this doesnt change the fact that it is only 900 lines/pixels high (screen resolution - the word resolution is used with ref to this figure in the article, the 10,000:1 is just contrast ratio IE the contrast between white and black and is very good in this case.) This can't fit any more vertical data on it so (perhaps with the exception of moi with its scalable UI) most UI's will look quite cramped vertically which isnt good for a lot of programs even 1080p video wont fit onto it natively at 100% which is why the 1600 high displays are so good as you can stack things up, if it was say 1200 that would make it much better in my book, much less scrolling up and down mois browser. Just my thoughts - id rather have a 30incher over this one especially for the money.
looks like one of those philips 21:9 aspect ratio tvs for movies that gets rid of the black bars on wide screen movies - great for movies but what about normal tv? Id rather have a bigger 16:9 tv and have black bars - cant say ive lost any sleep over them!
EDITED: 9 Jun 2009 by RHODESY
2674.13 In reply to 2674.11
Hi Burr,
Please read the specifications of the product :
http://www.necdisplay.com/Products/Product/?product=34f0e2d4-795b-4c4c-964d-da99e85a39fa
- Michel
2674.14 In reply to 2674.13
I already looked at the monitor. You can easily check this by setting your current monitor to 1440X900. Seems to me to be plenty of room for any app I'v ever used. Now just add twice as much to either side and have room to work many apps at once.
BTW: the 900 number has NOTHING to do with the LPI of any monitor as previously stated. It's merly an aspect ratio setting for fitting the image to the dimensions of the panel.
2674.15
Just wikipedia display resolution and also contrast ratio. 900 has EVERYTHING to do with the number of pixels (resolution) it can correctly handel vertically the official aspect ratio of this screen is 32:10 (look in the specs) which is the simplifyed factor of 2880x900px. Contrast ratio (10,000:1) has nothing to do with lpi or number of pixels/image size information on screen just the difference between the depth of the blacks and pureness of the whites so to speak. 900px high wont show 1080p video natively at 100% which kind of defeats the point of these for video editing.
2674.16 In reply to 2674.15
Wikipedia is a poor source of knowledge.
2674.17
Yes I almost put a caveat in there but still most common stuff usually seems correct, I wouldn't dismiss everything on it otherwise what's the point of it?
EDIT: did a quick google and found this in PCmag.com encyclopedia, the last sentence is what I was reffering to:
Monitor Size and Resolution
The standard resolutions are 640x480, 800x600, 1024x768, 1280x1024 and 1600x1200, the latter three being the most commonly used. For example, 1024x768 means there are 1,024 columns and 768 rows of pixels on screen. The higher the resolution, the more material is viewable on screen; however, a high resolution on a small screen makes text very small.
2674.18 In reply to 2674.14
Couldn't be doing with any less than 1200 deep myself. I moved from 1600x1200 CRT to dual 1280x1024 panels and I really missed the extra space at the bottom.
Now I am back on 1600x1200 I'm much happier :-)
Tony
(aka HamSoles)
2674.19 In reply to 2674.8
Just a quick review.
The Asus was recommended by a person on another NG. I was dubious at first because of the low price but the specs equaled or exceeded monitors at twice the price.
I am really pleased with it. It makes my older Acer 22" look pale and sick (though I previously thought it was fairly good).
For a budget price I think it would be hard to beat this Asus model (VK266H) and a much bigger viewing area (25.5") would be larger than I could take in at a single glance.
The colors are good and vibrant and the black and whites have great contrast.
cheers,
eric
Show messages: All  1-10  11-19
