Filling polygons with other polygons
All  1-4  5-10
2673.5 In reply to 2673.1
Hi Gabi, also one other note - if you are looking to tile an area with a sort of hexagonal grid rather than the regular rectangular layout grid, then that is possible to do by using the Transform / Array / Dir command in 2 passes, like this:
Is that possibly the kind of pattern that you were wanting?
2673.6 In reply to 2673.5
This was my idea because as he stated it was for a "LED" installation which would mean the hatch isnt adjusted to fill the geometry with the "best fit" but rather you just need to accept "what fits within". THen only keep whole peices after the boolean or trim.
2673.7 In reply to 2673.5
This isn't about the topic at hand, but I was wondering what you use to create your gifs?
Jesse
2673.8 In reply to 2673.7
Hi Jesse,
I use Camtasia Studio v5 (http://www.techsmith.com/), it's proven to be an extremely useful communication tool.
There are just so many instances where a screencap shows something much more clearly than trying to describe it with a bunch of text.
I also used it to make the video tutorials - it can generate a bunch of other kinds of video formats like WMV, Flash, etc... which are more efficient for something with a longer running time. But a GIF works great for something like 10-20 seconds or so.
2673.9 In reply to 2673.8
Thanks, It seems to do the job nicely. I can see how it would be very useful to you,
but the amount it costs compared to my need for it doesn't really match up too well. :-)
I once had a free gif maker that worked pretty well, but can't remember the name of it
or where I downloaded it from. I used to use it on simple Rhino turntable animations.
Jesse
2673.10 In reply to 2673.9
Hi Jesse, there are some free tools for screen capture available - one is called Wink (http://www.debugmode.com/wink/) and another one is called CamStudio (http://camstudio.org/). Those will work, they just are not quite as slick and easy/quick to use as Camtasia.
There is also a newer thing called Jing (http://www.jingproject.com/) which I think is free and also from the same people who do Camtasia so that could be another candidate.
Show messages: All  1-4  5-10
