Move face
All  1-10  11-13
2664.11 In reply to 2664.10
> I mean that after you pick the direction/distance,
> the command would not end and instead it would
> ask you if you wanted to do a boolean or not?
Well, it doesn't actually ask you for the next stage, all the options are in the one command window.
Almost like the fillet command in MoI, pick edge......input size.....type of fillet....enter
Anyhow, we'll have to wait until you implement the one step extrude/boolean command to comment any further.
Looking forward to it!
2664.12 In reply to 2664.8
>>>>But that would not really work for extruding a face rather than curves, since you can't really select a face and also the whole solid that the face belongs to at once...
Or would it???? A special face selection drilldown like the edge drilldown that is in swing when doing the extrude.. Select a solid, then on hover the faces are selectable also along with the edges (some kind of rollover like a hatch or something). Only kicks in when auto-bool extrude is in play.
Too complicated?
2664.13 In reply to 2664.12
Hi Burr,
> Too complicated?
Yeah, kind of complicated... I generally try pretty hard to keep selection working in a more uniform way between commands.
Show messages: All  1-10  11-13
