Tape measure
All  1-4  5-12
2641.5
Good work!
Looking at the Moi screenshot, it makes me think of some kind of space helmet...
Marc
2641.6
@Micheal: Thank you, and thanks for making such a enjoyable program.
@Ash: Yeah it is a little dark. I am trying to get the hang of Carrara. Are you the same ash on Polyloop? I may be asking advice from you there. (nudge-nudge)
@Marc: funny you should say that. That's what I do for a living. I design helmets all day long.
-Dooki
2641.7 In reply to 2641.6
Hi Dooki,
Yes I'm the same -ASH- from Polyloop.
Don't use Carrara much these days, though. Mostly modo now :-)
Main thing to look at is lighting. This is a big subject but here's a starter for 10:
http://www.3drender.com/light/3point.html
You can also get some good tips from looking at photography lighting tutorials. For your model google photo product shot lighting and also 3d product shot lighting. I play around a lot with lighting, lots of tweaking and rendering and tweaking and rendering and ....well you get the idea ;-).
2641.8
OK, here's another stab at the render.
Hey Ash, thanks for much for the tips.
-Dooki
Edit: Man, it still looks dark online. It's not as dark in Carrara.
Size: 18.4 KB, Downloaded: 66 times, Dimensions: 640x480px
2641.9 In reply to 2641.8
You're welcome dooki,
Try adjusting the levels or curves, depending on what options you have available in your image editor. I usually tweak a render in Photoshop a little bit to get a sharp punchy pic.
Tony
(aka HamSoles)
2641.10 In reply to 2641.9
Looks great dooki :)
Is the black material supposed to be a soft grip rubber? The reason I ask is a lot of the great contours you have there are lacking definition because of the lack of specular. Maybe try to apply some noise in your bump channel that is really small scale and intensity. Then increase your highlight value slightly(20-30) and reduce your shininess value(2-5) that should let you pick up some edge highlighting but still make it look like soft rubber.
2641.11 In reply to 2641.9
Thanks again sir!
I have not post-op in photoshop yet.
-Dooki
2641.12 In reply to 2641.10
Mahalo Grendel!
Yes, that is the material I was going for. I will try out your suggestions.
-Dooki
Show messages: All  1-4  5-12
