SAT export of spheres into Revit
 1  2-21  22
2634.22 In reply to 2634.21
Hi Igor, yeah I guess that explains it - it seems that Autodesk has made a lot of fixes in the Revit SAT importer in version 2010.
If you need to work with imported data a lot, then I guess it would be a good idea to try to update to Revit version 2010 as soon as you can.
> But even in 2010 not everything is perfect (if you remember my
> first test files (fromMoi.sat) - still not imported correctly
Yes, even though it seems to be quite a bit better it looks like they need to continue to work on improving it...
Hopefully they will be able to make progress on the next version similar to the improvements they seem to have done between version 2009 and 2010.
> (sort of what rhino has - with options for specific program sat
> output ie inventor, solidworks and so on - to counter possible
> problems)
That SAT export option that you are referring to in Rhino doesn't really seem to actually do very much. It looks like they are meant to be kind of a "preset" that is a group of individual settings. But almost all of them have the same options set. From the Rhino help file (in the index look at "SAT file export"):
quote:
ACIS types
Default
ACIS version: 4.0
curves are not exported
curve knots and surface knots are clamped
closed surfaces are split
ACIS Version 1.5
ACIS Version: 1.5
Exports curves
Curve knots and surface knots are clamped
Closed surfaces are split
ACIS Version 2.0
ACIS Version: 2.0
Exports curves
ACIS Version 3.0
ACIS Version: 3.0
Exports curves
ACIS Version 4.0
ACIS Version: 4.0
Exports curves
AutoCAD
ACIS Version: 4.0
Exports curves
Mechanical Desktop
ACIS Version: 4.0
Exports curves
Inventor
ACIS Version: 4.0
Does not export curves
Inventor does not read any ACIS object that is not a legitimate solid.
SolidWorks
ACIS Version: 4.0
SolidWorks ignores anything that is not a surface or a solid.
So note that all options have "Closed surfaces are split" (which MoI does not do) and "Curve knots and surface knots are clamped" being set (which MoI will do also).
The only major difference between the application-specific options seems to be whether writing curves is enabled or not, that's it...
Show messages:  1  2-21  22
