Move object by xyz coordinate ?
 1-15  16-21
2629.16 In reply to 2629.15
Hi Michael....
2629.17 In reply to 2629.16
Any of the tools that draw-move-scale that produce the "snap points" will populate the coords field with the value you want.
2629.18 In reply to 2629.16
Hi Anis,
re: Also I need to know the location of a "vertex".
Just use the exact same technique that I mentioned in the previous message (here)
Again - that is to just run any command that picks points within it, for example the line command.
Move your mouse to that vertex of the box, and then the active point will snap on to it - if it doesn't then it means that you have turned "Object Snap" off - turn it on again in that case by clicking on it in the bottom toolbar so that it is highlighted in orange.
When the point currently being drawn is snapped on to that vertex (it will display as "end" since it is at the end of an edge), then the xyz control will hold the value that you want.
2629.19 In reply to 2629.18
Hi Burr & Michael...
Thanks for the tips.
Yes, it work !
2629.20 In reply to 2629.1
Ehm, you can grab the object (e.g. a corner of rectangle or point), hold mouse down and and start typing coordinates via keyboard, then <Enter> :)
You can use absolute or relative coordinate - e.g. 3,3 or r1,1
Except the relative doesn't work in V2. Why?
Petr
2629.21 In reply to 2629.20
Hi Petr,
It's a bug that was introduced back with CPlane support in v2. The bug happened to be masked if a there were previous point picks before the relative coordinate entry within the same command (such as with drawing a line, etc..).
I've got it fixed up for the next beta, thanks for reporting it!
Show messages:  1-15  16-21
