Hi Anis,
> Then how to check the location of an object ?
Just run any drawing command - draw line, curve, circle, etc... it doesn't matter which one.
Then for the first point, move your mouse to that location so the point that is being picked snaps on to that spot and it will be displayed in that xyz control.
Probably at some point in the future there will be a special "analyze point" command when I get a chance to do a batch of analysis/metric type tools.
A "point object" like you are showing there is just not that frequently used, so it would not really do much good to only display coordinates when one of those special objects are selected.
When you created that point object, that would have actually been a good time to look at the xyz control to see what numeric location it was being positioned at.
