Trim command
All  1-10  11-14
2606.11
Thanks michael once again for your in depth reply. On your last post I would say there are three fragments. Perhaps rather than just having two sides as it were moi could temporarily auto group objects that have been split or partially split by the cutting object so here there would be three groups availiable for selection rather than a series of individual lines. This could be purely as an additional option on top of the current work flow. I remember working on a dummy test file and being frustrated by having to manually select the trimmed lines/objects - probably some sort of standing seam roof. Im often in two minds whether to use trim or bool in some situations as they often have the same outcome - which is no bad thing I guess.
2606.12 In reply to 2606.11
Hi Rob,
Do you happen to still have the file around? If so, can you please post it?
That would let me demonstrate on that particular example how to use a strategic window select to grab a batch of things, instead of manually clicking on each one.
> bad thing I guess.
Yeah for curves there are many situations where they work the same. But the difference is much more pronounced when you use them with solids - Trim will cut only the "skin" of a solid, while booleans will work on the volumes of a solid.
2606.13 In reply to 2606.8
Hi Rob - also I've got it set up for the next v2 beta so you can hit the Delete key in Trim to finish after picking pieces to discard, it works the same as Enter, clicking "Done", or right-clicking.
2606.14
sweet thanks for that michael im sure it will save me a lot of cursing! I think with the right clicking I do look at the top right info box but sometimes its too late or im a bit over eager on the buttons, also I'f im using that technique I like to look at the area im working on rather than the top right of the screen. Think for this command i'll just stick to my old fashioned delete key.
Thanks again.
Show messages: All  1-10  11-14
