cplane request
 1-8  9-28  29-48  49-51
2599.29 In reply to 2599.27
Here's a kind of interesting quick experiment with PastePart:
You set the "Repeat" checkbox to make it really quick to drop in a whole bunch of them . With Repeat activated, it's two clicks for each instance, one to place the base point and a right-click to accept the orientation.
2599.30 In reply to 2599.26
This is great stuff Michael!
"PastePart" looks fantastic, actually, more functionality than expected :) it's more like "AssemblePart"
How is "PastePart" activated, new icon or command via keyboard shortcut, is it going to act like Import where you choose an existing part as you mentioned and where will the origin be for the part that your bringing in, position as modeled?
Sorry for the barrage of questions but this looks so good, well thought out, well done Michael.
EDITED: 16 Nov 2009 by DANTAS
2599.31 In reply to 2599.30
Some things are just soooo easy now:
2599.32 In reply to 2599.31
And help lines are always possible between each drawings?
2599.33 In reply to 2599.30
Hi Danny, yeah it seems to be working really well.
It looks like it will be useful for several different things - certainly for sticking planes and circles together, but also for plopping down objects perpendicular to a freeform surface as well.
It's by right-click on the existing Paste icon, or by keyboard shortcut. I've added in a new default shortcut for it: Ctrl+Shift+V .
So Ctrl+V to get the regular simple paste, and if you want an "paste + set position & orientation", use Ctrl+Shift+V.
> part
PastePart just uses whatever is in the clipboard, so use Copy to put whatever part you want in the clipboard first, that's how you control what will be used.
There is a separate companion command though called "ImportPart" which you can activate by right-click on the File/Import icon. Instead of using what is in the clipboard, ImportPart prompts you for a file name, and then sucks in that file and lets you position and orient it in the same way. So if you want to set up a library of parts, you would use ImportPart to bring in one of your library items by picking its file name. In the file you can either position the part relative to the world origin and world axes, or if you have set a CPlane in the file it will use the CPlane as the source/base position.
For using the clipboard, you can either position your object being copied relative to 0,0,0 or you can set a CPlane to set the base point, before copying it to the clipboard. I think that I'm also going to make a companion command CopyClipboardBasePoint which will go as the right-click on Copy, which will prompt you to pick a base point to use for the clipboard origin point, that may be more convenient for some simple cases rather than setting the cplane.
The current plan is: if you have set a CPlane, the cplane defines the part's origin and axes. If you have not set a CPlane (either in the file for ImportPart, or at the time of Copy for copy/paste) then your part origin will just be 0,0,0 with world axes.
That's the current plan anyway, I think I should have the remaining pieces functional by tommorrow.
2599.34 In reply to 2599.32
Sorry, I don't quite understand.... Do you mean those 3 axis lines that are part of the orientation picker?
Yup, those axis lines show up on every individual paste, so you can adjust the rotation of every instance.
You do a right-click or press "Done" to signal that you are done adjusting the orientation.
2599.35 In reply to 2599.33
Until tomorrow then :)
Do you mean is it possible to use construction lines, if so, that will be helpful for positioning also.
2599.36 In reply to 2599.30
Also for ImportPart, you will be able to give the file name in a keyboard shortcut if you want, like:
ImportPart "c:\some folder\my filename.3dm"
If you do that, it will just use that given file instead of putting up the dialog box.
So you can set up some keystrokes to plop in and orient some predefined pieces.
2599.37 In reply to 2599.35
Hi Danny,
Construction lines work normally for when you're placing the base point (the first pick).
They are not quite so easy to use for the orientation step where you are dragging the axis lines around - since the orientation step works by dragging axis lines you already have the mouse down so you can't easily trigger a construction line at that point although it is possible if you move off the viewport and release the mouse button and then come back into the viewport.
But since they work easily on the first pick, you can just put in whatever ones you need for the orientation step then, before finishing the first pick.
2599.38 In reply to 2599.35
One thing I don't like too much is the axis triad lines tend to get obscured by the object you are pasting in.
It's not too bad because they highlight with a glow around them and a text label appears when you move over top of them.
If I make the lines longer, they kind of have an unwieldy feel to them and longer ones make it harder to see which is the primary one with the dot marker at the end of it.
I could make them display as always on top lines instead of being hidden by surfaces... But that then kind of messes with depth perception of the triad origin point though.
Here's one on the end of a booleaned cylinder:
< Construction lines work normally for when you're placing the base point (the first pick).
Cool that is the more important!
2599.41 In reply to 2599.40
I'm commin to join ya Weezy!!!
2599.42
Excellent!
2599.43
Woaw !
That's gonna be a useful feature. :-)
Can the user choose which face of the pasted object he wants to use. For example what if I want to snap the top of your rocket object instead of the bottom ?
Nice addition to the toolset.
2599.44 In reply to 2599.38
Looks like the next thing you'll have to work on is transparency :)
Will it work in edges only, like text, on the other hand if the object your bringing has a lot of edges it might still be a problem.
It would be nice maybe when the triad is activate it has the traditional, different colour for each axis kind of thing, would that make it more distinct also the object coming in could be the 'locked' color.
Just some ideas.
2599.45 In reply to 2599.43
Hi Bernard,
> to use.
Yeah, it will use the construction plane's origin (which by default is the world 0,0,0 origin point) at the time the object was copied to the clipboard as the base point.
So you can position the source object in relation to the origin to adjust that, either that or you can move the cplane to the spot you want.
Also I think there will be an alternate copy command that will prompt you to pick a base point for the copy.
So a few different methods will be available for controlling the part's source position.
So in the examples I showed previously, the pasted in object was in this place when I did Ctrl+C to copy it to the clipboard:
If you wanted the top to be the snap point, you would instead position the object that you are copying like this:
Or you can alternatively place the cplane instead of moving the object, or use the alternate copy command which will let you click a point and use it as the base point.
2599.46 In reply to 2599.44
Hi Danny,
> still be a problem.
The problem with doing edges only is that it would be different than all the other transform commands.
On a heavy model, drawing the edges actually takes longer than drawing the shaded surface part. Text is kind of a different case, because it has to create the full solid and also mesh it before it could draw the shaded surface. It's due to that creation step being involved that it does wires only in the Text preview.
In MoI v2 there is an optimization that kicks in when you are transforming a model after it gets to a certain number of faces, where it stops drawing the edges and only draws the shaded surfaces for the dynamic mouse feedback, to make for faster feedback.
So doing edges only for the output on a transformation type command is just not a good fit...
Well, that gets back to the stuff I mentioned a few days ago where I tend to try to minimize the use of colors in the UI in general.
One thing that I don't like about colorizing axis directions is that some people end up strongly associating the colors specifically with the world axis directions, so like if they see a red axis that means "World x axis" to them and can lead to confusion when it is pointing in a different direction (since it is a local axis for some operation) than some other red axis being displayed as the world axis, stuff like that.
There is a big text label that shows up when you mouse over every axis line and the axis line gets a glow around it, and the glow shows up on top of everything. So it's not particularly difficult to figure out what is what after you cruise the mouse over things.
Also colorizing would not do any good if the axis lines were all submerged anyway...
That would also be way different than other transform commands. When giving a preview for things, I try when possible to do "What you see is what you get", instead of shifting things suddenly at the end. Like for example if you have a red object and you use the Transform/Copy command (the one like Move not the clipboard one) to make copies of it, you get to see that each object is red when you place it, stuff like that.
So yeah probably some transparency level would be the best way, but that won't be possible until some point in the future.
2599.47 In reply to 2599.45
I knew there would be several options for the user to choose from ! :-)
Personally, I like the idea of an "alternate copy command".
Thanks Michael
2599.48 In reply to 2599.47
Hi Bernard, yeah the idea for the alternate copy command is that it would be launched by a Right-click on Edit/Copy, or by doing Ctrl+Shift+C (instead of just Ctrl+C).
That will then ask you to pick an origin point which will be used to define the base point for "PastePart".
So that will be one of the easier ways to use this - if you want to do a Copy/Paste with this repositioning mechanism, use Ctrl+Shift+C to copy it instead of just plain Ctrl+C so you can pick the base point, and use Ctrl+Shift+V to paste it instead of just plain Ctrl+V.
That allows the simple regular Ctrl+C / Ctrl+V behavior to remain the same instead of making extra steps for them.
Show messages:  1-8  9-28  29-48  49-51
