Cad software
All  1-6  7-13
2594.7 In reply to 2594.4
Yes, if you export them as .dwg files they read just as well as in AutoCad.
eric
2594.8 In reply to 2594.7
Hi Eric - MoI itself does not currently have a DWG export... You're probably using Rhino to do that part?
I'm not sure if Joao (the original poster in this thread) has Rhino or not.
2594.9
Hy guys,
thanks for the tips regarding low cost software.
In fact the tip for Viacad seems ok. In the case of Alibre i think there are some minor issues on the agreement regarding use.
The issue here is because the software is to a third part user and it will be an issue to all customers i sell in the future, so on one hand it must be inexpensive or free to give it away with Moi and on the other hand must be very easy, to follow Moi philosophy and to not take much time preparing information to fabricate.
The issue on the Dwg is that as Michael mention, does not exist export function over this extension...
João
2594.10 In reply to 2594.8
Yes, my error ...
I move pretty fluidly between the three softwares and sometimes forget which is best at what.
cheers,
eric
2594.11
Hello,
I´ve been searching for a solution, because probably i´m not the only to have this problem, so a solution could be used widely.
Can you look at:
http://www.workxplore-3d.com/us/
It seems a very good viewer on the free module, because among other items has the possibility to read Iges and Step what in the case of Moi solves the problem.
After 30 days we loose some advanced options to dinamically measure radius and other but maintain possibility to measure with points and so on what from my side it´s enough.
Can anyone test this as more experience user´s of Moi to check about the quality or not of this solution?
Joao
2594.12 In reply to 2594.11
Hi Joao,
I think the best low cost alternative is viacad, there is even a cheaper '2d only' version. You can directly import view from a 3dm file.
Alibre can be a nice translator also to output dwg, you can dimension and detail it in doublecad or something else afterward. A bit tedious though.
It all depends on the type of drawings you wish to make, the level of detail and quantity you will output.
I sure hope to see dimensioning tool in Moi, it would make an amazing tool!
Marc
2594.13
I hope in the near future we wont need to use extra softwares for documentations and Moi will include all these feature :) This is my dream, a way for fast and enjoyable design :)
Show messages: All  1-6  7-13
