Scale Array Crazyness
All  1-2  3-7
2571.3 In reply to 2571.1
Hi Brian, make sure to include a single Point object along with the objects that you are arraying, it is used as the center point of the scale.
The point can be drawn using Draw curve / More / Point.
The point should be placed at the spot that you want the scaling to happen from, select the point along with your objects when you array them.
See here: http://moi3d.com/forum/index.php?webtag=MOI&msg=275.109
for the original ScaleArray post that has some more details and an example image.
2571.4 In reply to 2571.3
@#&^^((-- I forgot the DOT!
How the brain can detiriorate in 24hrs!
Brian
2571.5 In reply to 2571.4
Aaaaahhhhh
Brian
Size: 174 KB, Downloaded: 141 times, Dimensions: 1024x640px
2571.6 In reply to 2571.5
Are you create those model as hobby or real project ?
Looks like an alien ship :)
2571.7 In reply to 2571.6
Anis
Nothing fancy. Time to spare, nothing in mind----just fiddle!
(That model is only trying to capture the one the Bogey came visiting in here last night!)
Snot original!
Brian
Show messages: All  1-2  3-7
