V2 beta Apr-12-2009 available now
 1-11  …  172-191  192-211  212-216
2570.212 In reply to 2570.211
Hi Michael!
I have figured it out what exactly makes spheres not importable into revit..
pls see attached file..
As I said earlier .3dm is the cause - may be a tweak for spheres can be done in options on export - to help them be structured like in Rhino or AutoCad
Regards,
Igor
Also there was a bug fixed in Rhino for sat fails (as it happened only recently - just making sure MoI doesn't have it as well..)
What's New, SR4b (27-Aug-2008)
Bug Fixes:
Export SAT: the correct unit system is now saved in SAT files. This makes it possible to read Rhino's SAT files into other applications and have them maintain the correct size.
EDITED: 11 May 2009 by IGOR
Size: 165.3 KB, Downloaded: 72 times, Dimensions: 1600x1172px
Size: 122.9 KB, Downloaded: 39 times, Dimensions: 1600x1170px
2570.213 In reply to 2570.212
Hi Igor,
Sorry, I'm not really sure what the difference is - I guess you are showing a screenshot there where they look different in AutoCAD? Unfortunately I can't really debug a screenshot, I need actual model examples that I can examine.
I need to know exactly what the difference is before I would be able to do that.
Have you run into any problem with units with the MoI export? If not then there is no bug there... MoI's code for SAT export is totally different than Rhino's so there isn't too much reason to expect for bug reports in Rhino to be the same in MoI...
2570.214 In reply to 2570.212
Hi Igor - in those screen shots you mention things like "This is an imported SAT file..." - it would be a big help if you could include all those related files instead of only a screenshot. Like if you have some example about a particular SAT file, please post the SAT file (and any original .3DM file as well) so I can try to examine the model data.
It is hard for me to tell specific things like details about the surface definition and topology just by looking at a screenshot.
2570.215 In reply to 2570.214
Hi Michael!
I have actually collected a few more findings, but will post on them later on - lets wait for the person you send the files I earlier provided for his/her verdict
Regards,
Igor
2570.216 In reply to 2570.215
Hi Igor, I'm going to start a new thread for continuing the Sphere / SAT export issue.
EDIT: new thread for this discussion is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2634.1
EDITED: 13 May 2009 by MICHAEL GIBSON
Show messages:  1-11  …  152-171  172-191  192-211  212-216
