Bug: 3 point arc prompts for wrong order of points
2561.1
This is the Jan-19 2009 beta.
While using the 3 point arc curve tool, the program expects me to click a start, end, then "on-arc" point. However, the upper right hand corner prompt tells me I should specify start, "on-arc" point, then end point.
And that, gentlemen, was the most trivial bug ever reported.
2561.2 In reply to 2561.1
it's not a bug, it's an error of help text, but the function arc works fine ;)
2561.3 In reply to 2561.1
Hi Otterman,
:) Thanks for reporting it anyway!
I've got it fixed up, and you can update your current version with the attached Arc3pt.js file to get the fix. Just copy it over top of the old file in the \commands sub-folder inside of MoI's main installation folder.
2561.4 In reply to 2561.3
Just checked my updated V1.1 & it has that same "miss-info".
Can I also add this same js file to V1.1 or is this file a V2 Beta specific one?
regards Colin
2561.5 In reply to 2561.4
Hi Colin, yes in this case you can also update v1.1 with the same file.
