Hi olio, well the red for delete is not particularly unusual, that one seems quite normal and familiar feeling.
The undo/redo is not quite as much of a slam dunk, but it is not very far away from other things either, here is a screenshot from Word 2003 for example:
MoI's current ones are similar enough to that to make that pretty reasonable.
For some of these things it is not too great to stray too far away from the typical things.
Again, if you have some better ideas it helps a lot to actually see the "improved" icons rather than just some text description of them...
Maybe a little bit less saturation on the undo/redo would be a good tune-up but it is a pretty tiny detail.
