image location
All  1-2  3-4
2552.3 In reply to 2552.2
Setting up the images took time and so just re-picking new images was undesirable.
However, after you pointed out that the pictures in the same location actually moved with the file, this kindof handled it. I thought I tested this and it didnt work, but it does as you describe.
One way to enable editing the path would be to make the listbox item double clickable to open the opendialog for setting a new path. (though I dont find this behavior in MoI anywhere else).
I'll explore a bit and post back.
2552.4 In reply to 2552.3
Hi Burr,
One tip on this part - don't erase the old image until after you have drawn in the replacement.
The corners of existing images are available as snap points when drawing in a new image, so you should be able to snap in an image with an updated path right over top of the previous one. Then delete the old after you have placed the new one.
> MoI anywhere else).
Yeah, I've tried pretty hard to avoid using double-click for sort of "main" functionality.
But I'm not necessarily against it for supplementary stuff, it seems like it would be a good thing to do in this case to avoid adding more visual stuff to the current UI.
I've added this to the wiki wishlist here: http://moi3d.com/wiki/Wishlist to keep track of it.
Show messages: All  1-2  3-4
