FERRARI 599 GTB
 1-12  13-32  33-52  53-71
2546.33 In reply to 2546.32
Hi TwinSnakes,
> Dont forget Paq's Snowman tut as well.
Thanks - this one is added to that list now.
2546.34 In reply to 2546.1
Lyes,
That is some amazing work you've done, thanks for providing the videos of your work flow.
2546.35
Great model and tutorial. But how does one create the air outlets in the hood/bonnet?
2546.36 In reply to 2546.35
*bump*
How does one create the air outlets in the hood/bonnet?
2546.37 In reply to 2546.36
http://cid-5f80634ecf17f939.skydrive.live.com/self.aspx/.Public/Bonnet.wmv
THis is a link to the video found at the begining of this thread.
2546.38 In reply to 2546.36
hi displaced i will update the video or make new video for the outlet this weekend
2546.39 In reply to 2546.38
Thanks a lot, lyes. Much appreciated.
2546.40 In reply to 2546.39
hi dispatched here is the video
hood-outlet
2546.41 In reply to 2546.40
That was actually fairly complicated and I'd never figured out that one by myself. Great stuff.
A whole big bunch of thank-yous to you, lyes. You da man! :-)
2546.42 In reply to 2546.2
video links dead
2546.43 In reply to 2546.20
Hi lyes,
Could you please describe how to setup blueprints in MoI.
2546.44 In reply to 2546.43
Hi ket,
You can use the View > Image command to place reference images into the viewport:
Some details on it here:
http://moi3d.com/2.0/docs/moi_command_reference5.htm#image
And also see these previous posts for some descriptions on different ways to place the images:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2501.14
http://moi3d.com/forum/index.php?webtag=MOI&msg=2501.15
http://moi3d.com/forum/index.php?webtag=MOI&msg=1982.6
2546.45 In reply to 2546.44
Great tutorial. I gave it go, but could not follow along - got crap results and gave up. You got skills, man!
-BbB and Phr0stbyte models are for sale here: http://www.turbosquid.com/Search/Artists/Phr0stByte?referral=Phr0stByte/
2546.46
Too awesome - if it wasn't late and a Tuesday night I'd be stuck into this already.
The video download links do seem to be dead. Any chance you could fix this or upload to Vimeo/Youtube?
EDIT: for anyone wanting to download the videos, open the "network" panel in Chrome. As you press play, a working link for the MP4 will appear - you can visit this link to download. I would recommend downloading these and playing them in slow motion (e.g. using VLC) as it makes them much easier to follow.
EDITED: 28 Apr 2011 by AARONNEWTON
2546.47
I'm also wondering how you achieved the breaking up of the lines at 1:28 on the "bumper" video. I ended up using trim and inserting a trim point at the point where the lines intersected.
2546.48
Sorry for the multiple posts, but I'm quite stuck.
For the "Front Wing and Door" tutorial around 2:59, my projected curve looks quite different from the tutorial.
Mine:
Theirs:
I'm specifically referring to the vertical alignment of the projected curve in the second image, which seems to be right off. Can anybody clue me in on where I might have gone wrong?
2546.49 In reply to 2546.48
Hi Aaron, sorry it's kind of difficult to understand that - could you possibly post a 3DM model file of your model so far so that we can take a look at your curves directly and be able to zoom in and inspect them and so forth? That may help to better understand what you are seeing.
2546.50
Sorry about that Michael (and thank you for replying).
I have attached the file (with images etc.) for you as requested.
EDITED: 3 May 2011 by AARONNEWTON
2546.51 In reply to 2546.50
Hi Aaron, thanks for posting the file, that helps a lot.
So from what I can tell it looks like you've got a difference in the projected curve because your surface is kind of flatter than the one from the tutorial, I think the one from the tutorial kind of curves out more.
A projection on to a more curved and rounded type shape will make a different result than a projection on to a flatter type shape.
Here's an area where I kind of noticed the difference:
Your surface there seems to be kind of straighter and flatter than guide curve that you've got at the end there.
Did you possibly do a sweep using only the profile from the opposite side of the surface and not including the profile from the side the arrow is pointing to above to make the sweep result match that end curve?
2546.52
Hello Michael,
Thank you for the feedback. I think you're correct about this. HOWEVER - if you check out 3:36 on this video, it looks like the screenshot below:
This is quite close to what I have.
When I use a loft, how can I get it to take these vertical curves into account (i.e. so that the lofted surface would actually be touching these curves)?
Show messages:  1-12  13-32  33-52  53-71
