A bomb in 3D land :)
All  1-4  5-18
2532.5 In reply to 2532.4
A great find Pilou!
Works beautifully in SketchUP.
Are people getting back to what I used to be involved in back in the 1940s?
Great principles!
Brian
http://gilbrethnetwork.tripod.com/therbligs.html
http://en.wikipedia.org/wiki/Therblig
2532.6 In reply to 2532.5
or is the link to download the librery and the plug ins?
2532.7 In reply to 2532.6
The SketchUP plugins zips are on the links but you have to register as a site member for them to show up.
Brian
A new free Parametic Modeling for SKetchup is released in version Beta!
By Samuel T
https://sketchucation.com/pluginstore?pln=parametric_modeling
2532.10 In reply to 2532.9
Works fine in 2017 Make :)
The beta 2 of the free Parametric Modeling by Samuel T is released!
https://github.com/SamuelTS/SketchUp-Parametric-Modeling-Plugin
the cool thing is that you can use the Boolean functions even inside the free 2017 make!
EDITED: 22 Mar 2021 by PILOU
ParametricModeling for SketchUp
The free version 0.0.3 is released https://sketchucation.com/pluginstore?pln=parametric_modeling
What's new in version 0.0.3?
- The process of adding nodes has been improved: you can place new nodes faster!
- Vectors and points can be extracted from the active model via the context menu.
- In the "Calculate" nodes, you can use the rand function to get random numbers.
- As soon as a material or a layer is added or deleted, the Node Editor reloads.
- A door is available in the example drawings. Thanks to Simon Joubert for this one.
- Although it is not recommended, one can read/edit the .schema files more easily.
V4 of Parametric Modeling!
Tube, Tag, Erase...
v 0.5 Parametric modeling
- Align" and "Get Points" nodes.
- Copy" and "Move" nodes become backwards compatible.
- Decimal number with adaptive pitch.
- Arrows on screens removed, they stay on keyboard!
- Deg function to convert Radians.
- The selected cable is highlighted.
- The plugin has been translated into French. And Chiness!
https://www.liutao91.cn/4020.html
EDITED: 24 Apr 2021 by PILOU
2532.17
Parametric Modeling For James Bond! ;) free one for SKetchUp free 2017 Make
by Samuel T
What's new in 0.0.7 version?
- "Move" node has evolved without compatibility break.
One can use formulas to define XYZ positions...
See the "Parallel Copy" example schema.
- Plugin handles more errors. E.g. a zero radius.
- Nodes Editor contains a link to a wiki hosted by GitHub.
- For developers: Node module was refactored.
EDITED: 3 Jun 2021 by PILOU
Show messages: All  1-4  5-18
