A bomb in 3D land :)
All  1-11  12-18
The beta 2 of the free Parametric Modeling by Samuel T is released!
https://github.com/SamuelTS/SketchUp-Parametric-Modeling-Plugin
the cool thing is that you can use the Boolean functions even inside the free 2017 make!
EDITED: 22 Mar 2021 by PILOU
ParametricModeling for SketchUp
The free version 0.0.3 is released https://sketchucation.com/pluginstore?pln=parametric_modeling
What's new in version 0.0.3?
- The process of adding nodes has been improved: you can place new nodes faster!
- Vectors and points can be extracted from the active model via the context menu.
- In the "Calculate" nodes, you can use the rand function to get random numbers.
- As soon as a material or a layer is added or deleted, the Node Editor reloads.
- A door is available in the example drawings. Thanks to Simon Joubert for this one.
- Although it is not recommended, one can read/edit the .schema files more easily.
V4 of Parametric Modeling!
Tube, Tag, Erase...
v 0.5 Parametric modeling
- Align" and "Get Points" nodes.
- Copy" and "Move" nodes become backwards compatible.
- Decimal number with adaptive pitch.
- Arrows on screens removed, they stay on keyboard!
- Deg function to convert Radians.
- The selected cable is highlighted.
- The plugin has been translated into French. And Chiness!
https://www.liutao91.cn/4020.html
EDITED: 24 Apr 2021 by PILOU
2532.17
Parametric Modeling For James Bond! ;) free one for SKetchUp free 2017 Make
by Samuel T
What's new in 0.0.7 version?
- "Move" node has evolved without compatibility break.
One can use formulas to define XYZ positions...
See the "Parallel Copy" example schema.
- Plugin handles more errors. E.g. a zero radius.
- Nodes Editor contains a link to a wiki hosted by GitHub.
- For developers: Node module was refactored.
EDITED: 3 Jun 2021 by PILOU
Show messages: All  1-11  12-18
