Right click
All  1  2-6
2530.2 In reply to 2530.1
Hi scarabrae - most likely you have the new IE version 8 installed that was released just a week or so by Microsoft?
That version happens to have a bug in it which prevents MoI from showing the "Done" and "Cancel" buttons which are normally supposed to show up in the upper right options area.
Basically without those buttons showing up, the regular command flow is messed up and that has a side effect of the curve command behaving like you are describing.
At the moment you'll need to run MoI on a machine with IE7 or IE6 on it instead for it to work properly.
But I should be putting out a new patched version of MoI v1 pretty soon here which will avoid the problem though.
2530.3 In reply to 2530.2
Hi Michael
That is likey to be the problem.
Will attempt to remove version 8 of IE.
Thank you
2530.4 In reply to 2530.3
Hi scarabrae - that would do it... I think to remove it you need to look for "Windows Internet Explorer 8" in the Add/Remove programs list, so it is in the "W" part of that alphabetical list (kind of easy to miss it in there).
But also it should not be much longer before I will be able to put out an updated trial which will then work with IE8, something like a couple of days.
2530.5 In reply to 2530.4
Thanks for the info.
I have removed IE8 and I can play with the demo. Exports wonderfully to modo (quads + ngons).
I am sure I will be adding Moi to my toolkit. Thanks for your work and creativity.
2530.6 In reply to 2530.5
Thanks very much scarabrae!
Show messages: All  1  2-6
