To Michael... Is this a bug?
All  1-4  5-9
253.5 In reply to 253.2
Pilou wrote:
> Just déplace the circle :)
> But sure when circle is there, there is something curious :)
> maybe because it's on the rail path?
Yup, the shapes are treated differently if they are on the path. If they are on the path they will not be modified, that shape will be used right at that spot on the rail.
Once you move the circle away, you are triggering the "auto-place" mode that will automatically position the profile for you.
253.6 In reply to 253.3
> Check the attachment. It seems that the circle starts from zero diameter
> and ends to the highest value from both ends but not covering the same
> length of the curve.
Yeah, this was a bug in the geometry library - I've fixed it up for the next beta so it will be consistent along the length as you would expect.
> Even better, this should be adjustable, don't you agree?
The way you can adjust this for the sweeps is by placing the cross-section at a particular spot on the rail, or also by placing more cross-sections.
For example if you want the maximum bulge of the pointy sweep to be at this particular point:
Then draw a circle there. To easily draw the circle, do Circle/Center, place the center point at the spot on the curve, then check the "Vertical" checkbox option before you click the radius point - this lets you draw a circle that is flipped up from the plane and it should be easy to track it perpendicular to the curve like that. Then when you sweep with it, you should get this type of result:
By using this method you should be able to control the placement of the maximum spot as a workaround for the bug in the current beta.
Eventually I do want to show some grip points so that you can slide around the cross-sections that were placed in the "auto-place" mode to fine tune things. I think this would be more the type of adjustment that you're looking for. But I don't think that I will have that particular thing ready for V1.
253.7 In reply to 253.6
All works fine when you have the circle on the path and modify it :)
But is it an automatic way for move it on the path with perpandicularity to the path?
Now it's move along the path"On" but not "perp" :)
Seems we are obliged to make a move + rotation ?
253.8 In reply to 253.7
Yes, right now that is the way to do it.
At some point in the future there should be some additional tools to make this easier, but for a while just move + rotate will have to suffice.
253.9 In reply to 253.8
For the moment :)
Show messages: All  1-4  5-9
