Boolean sub bug
 1-7  8-27  28-31
2518.28 In reply to 2518.26
I had thought I read about that on the Integrity site and it required the integration with their tesselator which was a reason why Michael couldnt even consider it, but he pointed out I was wrong.
I must have been confused!
I've been puching points in MoI alot latley with the patch surface show points thing. Its really good for creativity but very hard to control. I've been trying to figure out a means to get a more precise "definition" of points as opposed to a standard parallel pattern.
2518.29 In reply to 2518.28
Hi Burr, actually even if it did depend on their tessellator I would be able to use it - that tessellator is in the library and I can use it if I want to.
I don't use it not because it is not available, but rather it did not do what I needed it to do, like wasn't fast enough for display meshing, didn't generate n-gons for export meshing, had problems like triangle leaks too often, and some other things...
But yeah a subdivision surface would be a new kind of surface construction method that would be used in addition to things like sweeping, lofting, etc... It would be like "make surfaces from this point cage". It doesn't really have anything specific to do with the tessellator.
2518.30 In reply to 2518.29
As long as I learn something new everyday, I am a success!
Thanks.
2518.31 In reply to 2518.24
>> As us programmers say,
>> "The last bug is gone when the last user is dead."
Or more likely (as in with Softimage) "The last bug is gone when the last user has left for another package..."
-Will
PS - Either way, it would be great to eventually have this in MOI Michael, especially if it can be done - I feel that would be the feature that brings to fruition "build it and they will come" for MOI...
Problem then is do you prefer to be comfortable with a million bucks or way less comfortable with 20 million bucks?? (More customers, more support etc...)
EDITED: 27 Mar 2009 by WILLBELLJR
Show messages:  1-7  8-27  28-31
