offeset prblm
 1-20  21-34
2513.1
offeset not working if you have use G2 & G3 on fillet options.... Or am I doing something wrong?
EDITED: 17 Apr 2009 by YANNADA
Works for me for 1 to 3 cm
Size: 24.1 KB, Downloaded: 16 times, Dimensions: 308x324px
2513.3 In reply to 2513.1
Hi Yannada, looks like a limitation in the geometry library where it doesn't currently handle surface offsetting an arbitrary surface of higher degree. It can handle fillet surfaces of higher degree but not the corner patch. If you delete the corner patch then you'll be able to offset the rest of this shape.
This is a problem in the geometry library which I will report, but it may take a while for them to make a fix.
2513.4 In reply to 2513.3
geometry library! Who are they Michael, this higher power? :)
2513.5 In reply to 2513.4
Hi olio, I use the Solids++ geometry library from http://integrityware.com/
I also have quite a lot of custom code developed for a bunch of things, but surface offsetting is one of the things that comes straight from their library.
2513.6 In reply to 2513.3
is not really a coincidence, I have been running some tests also sort of studying their geometry library which would help me to clear things up in my head.Therefore I don't have crazy requests from you in the future. Anyhow thanks for the reply. http://www.integrityware.com/tutorials/Max/Release20/Power_Offset/Power_Offset.html
2513.7 In reply to 2513.2
Pilou you dont mind me asking what are the steps you took there?
2513.8 In reply to 2513.7
Looks to me like Pilou used a regular circular fillet shape, which doesn't happen to run into the problem.
Yannada, one other general tip is that it can be better to apply fillets after offsetting rather than filleting first.
I don't use any fillet before apply offset with your example file 3dm
But something curious : is it normal that over 3 cm nothing works in my example above?
your example was in mm, I change it in cm or without unit system
If I take 3 faces of a normal cube I can offset any measure!
EDITED: 24 Mar 2009 by PILOU
2513.10
it makes seance, thanks you gentlemen
2513.11 In reply to 2513.9
> example file 3dm
In the example file that I downloaded from the above (test_34.3dm), there was already a fillet applied. Did you get a different file?
It looks like your example is just an image with no .3dm model file? Could you please post the model file so I can take a look?
2513.12 In reply to 2513.11
It's the model of Yanada that I have loaded! Only change unities! mm --> cm
After 3cm ??? Offset seems not works!
2513.13 In reply to 2513.11
I did post one only file...test_34.3dm
Perhaps Pilou did build his own. ( Pilou Pilou I did click the same button 10 times ) "LOL"
2513.14 In reply to 2513.13
Yes I had loaded only your test_34.3dm !
2513.15
Here is another one. Indeed not able to offset
2513.16 In reply to 2513.12
Yeah, it looks related to the same problem, it is having a problem with the corner patch.
If you delete the small rounded corner patch, you can then go above 3cm.
That is interesting that it works when you scale the object down by 10 times though.
Same advice as before though - it works better to apply the offset to the plain box, and then apply fillets to everything after offsetting has been done, rather than filleting before.
Message 2513.17 deleted 24 Mar 2009 by YANNADA
2513.18 In reply to 2513.15
Hi yannada,
Does it have a high degree? Singularities? Large or small size in units?
Those are some of the things to look for that the offsetter does not like.
But it's hard for me to tell any of these things just looking at a screenshot, can you please post the model file?
That is a famous bug of the library!
Does the guys are reactive?
2513.20 In reply to 2513.18
Show messages:  1-20  21-34
