Move a face
2507.1
Hi
Im very new to MOI - still testing - and have a very simple question:
Suppose I need* to move the (selected on pict) face up or down, +Z/-Z... How do?
*Client ask after all work done. Here face on a simple cyl. but can be part of more complicated object.
2507.2 In reply to 2507.1
Extrude it? Move it? Copy it?....
Depend of the nature of the base bottom cylinder
2507.3 In reply to 2507.2
@Pilou: C'est amusant que ce soit toi qui me réponde aussitôt :)
Note for all: Frenchy Pilou is 'the french MOI evangelist' and I discover MOI after reading his (thousand of) post about in other 3D forum.
Explain 'Extrude it' please...
Edit: I can extrude circle but need many op. to clean the solide (delete old face, extrude, join, ...) or im missing something simplier?
EDITED: 23 Mar 2009 by YCARRY
2507.4 In reply to 2507.3
@Icarry
C'est impossible de répondre à cette question sans le fichier 3DM à modifier car il y a au moins une demi douzaine de solutions différentes en fonction de l'état du volume, si c'est une "primitive", ou simple volume...
PS Il y a une forum français itou ici-même ;)
2507.5 In reply to 2507.3
Salut ycarry,
A premiere vue si tu as un solide, tu fais un extrude a partir de la face selectionnée, avec l'option [cap end] activée.
Tu te retrouves avec 2 solides, il suffit ensuite de les additionner, (booleans/union)
2507.6 In reply to 2507.5
Paq: << face extrude [cap end] then Union >> (keep english, mates, please ;) )
so i cant 'simply' move a face... like in Shark or Rhino
Here Wenatchee(Rhino4) on Mac: "move a face" option -> select, move. that is.
Suppose object is a watch corps... Laptop on knees in client cabinet:
Client: "Okay, move this face 0.1 mm up and I validate... .iges file must be in HK in 2min."*
*real!
2507.7 In reply to 2507.6
If you have yet a face no problem to move it! :)
2507.8 In reply to 2507.6
Hi ycarry,
No you can't simply move a face like that. (if it's part of a solid)
I suspect rhino or shark are in fact doing the whole 'extrude-boolean union' as a combo, making you thing you're just moving a face.
Michael will probably give a better answer soon ;)
2507.9 In reply to 2507.7
Im a real noob with MOI... show me how to move the (in first pict of thread) face up, please!
Edit: oops i answer to pilou post.
Ok, how clean the solid after an up move?
Maybe the more simple is Select all / Separate then move ;)
2507.11 In reply to 2507.3
Hi ycarry - MoI does not currently have a "Move face" command like the one in Rhino that you are talking about.
If you are already familiar with that one in Rhino, then one easy solution is for you to use Copy/Paste to move the object into Rhino, use the tool that you are accustomed to over there, and then Copy/Paste back into MoI.
Otherwise there are a few different methods you can use the result that you want in MoI.
Probably the most simple is to select the bottom face, and use Extrude by the distance that you want to move it. Now you have a small solid cylinder nested inside of the larger one - to finish the model select both cylinders (the outside one and the new nested inside one) and run Construct / Boolean / Union, which will merge those 2 pieces together into one new piece and you're done. If you want to move it downards, then extrude downwards and use Boolean Difference instead.
Another method is to select the bottom cap and inside wall surfaces, and use Edit/Separate to break them out into a separate object. Now you can use Transform / Scale / Scale1D to scale the height of that fragment, pick a point on the top level as the origin for the scale. When you are done, select that inside piece and the outside piece and use Edit/Join to glue them back together into a solid.
Then the other method is to also use Edit/Separate to break the interior wall out into its own surface. Then turn on control points, and select the bottom row of control points and move them up. This one is more like what the Move Face command in Rhino does for you behind the scenes.
Even another method is mentioned by Pilou - separate out the bottom cap so it is an individual object, move it up to where you want, then delete the interior side wall and loft between the edges to form a new interior wall (or trim the old interior wall by the bottom cap in its new location) and use Edit/Join to glue the pieces together.
But anyway, the Extrude + Boolean is maybe the easiest.
2507.12 In reply to 2507.11
<<Another method is to select the bottom cap and inside wall surfaces, and use Edit/Separate to break them out into a separate object. Now you can use Transform / Scale / Scale1D to scale the height of that fragment, pick a point on the top level as the origin for the scale. When you are done, select that inside piece and the outside piece and use Edit/Join to glue them back together into a solid.>>
Yes thats the solution i find too as a good one ;) : [Separate, scale 1d, join] is a safe solution (as adj. faces are concerned too).
Thanks all for help! now i return to MOI adventure... tadaaa...
