Moi Vs Rhino
2497.1
Hi there,
I am currently a Rhino3d Power user, only one question can Moi3d do all which Rhino3d does ???
Also i dont see curves from 2 views option in moi which is extremely necessary for doing product models.
Pls advice
SaNjU.
2497.2 In reply to 2497.1
Hi Sanju,
I use Moi and Rhino.
After trying Moi for 1 month i purchased it.
The booleans are far better and Moi never crashed.
It has less commands so i don't loose time in searching
them.
You can use copy/paste into Rhino.
EDITED: 20 Mar 2009 by PAOLOLOBBIA
what are curves from 2 views ?
2497.4 In reply to 2497.3
Like this image:
Size: 55 KB, Downloaded: 432 times, Dimensions: 381x460px
2497.5
Isn't the 'curves from 2 views' something like extruding 2 curves and do a /curve/intersection from the 2 surfaces ? Or maybe I don't get the command :S
EDITED: 3 Dec 2015 by PAQ
2497.6 In reply to 2497.5
Hi PaQ,
Yup, not just similar to that - it is exactly a shortcut for doing that.
I've been meaning to add this in to the Construct/Curve/Isect command if you have 2 planar curves selected that do not otherwise intersect.
But yeah for now you can use Extrude + Create intersection curves to do it.
2497.7 In reply to 2497.6
Is curves from 2 views simple enough to make it into v2 Michael?
-Will
2497.8 In reply to 2497.7
Hi Will,
Yes, I believe so.
2497.9 In reply to 2497.8
That's great to hear - thanks Michael!
-Will
