UV from Planar Oddity
All  1-3  4-6
2493.4 In reply to 2493.3
Hi Nick,
> I had no idea that the UVs were assigned to the bounding box. :)
Well, they don't have to be, that just happens to be the way that it is done in Rhino.
In MoI I do a built in shrink-down of the surface when it is meshed, so if you export to a mesh format from MoI you would see all those UVs looking the same.
2493.5 In reply to 2493.4
Could be nice if the UV could automatic match the surface and there would be no difference between NURBS and mesh. Could be important if MoI supports textures. ;)
If I remember me right textures are planed for v2 or? If yes, will it be possible to do some basic UV manipulations like repeat/offset/angle?
2493.6 In reply to 2493.5
Hi Micha, no textures are planned for the display in v2, just basic colors only.
Currently the focus is on basic colors for helping with object organization, and also setting up material assignments so that it will be easier to set up textures and stuff like that inside of your rendering program.
In the future I do want to add support for seeing textures in MoI but that will be a ways off still.
Show messages: All  1-3  4-6
