Scene browser progress
 1-15  …  36-55  56-75  76-95  96-115  116-135  136-141
2470.76 In reply to 2470.75
>>toggle all layers
>> visible/invisible except the one that is ctrl+clicked.
>I've been thinking of using right-click for that purpose.
>A similar thing is currently set up for the checkboxes in the Object Snap menu
Yes. I forgot that it was already implemented in the Snap menu. And it keeps the interface coherence.
>I'm hoping to not have a separate lock icon,
>instead I'd like to have the eye icon show as a lock instead when all those objects are locked.
>But I haven't quite worked out all the details yet.
Do you see it as a triple state button ?
While the interface would stay clean, the states alternance would add one more step to the user.
Another "modifier key + mouse" combination would be more direct.
- Michel
2470.77 In reply to 2470.76
Hi Michel,
Not in the sense of a triple toggle cycling by left-clicking - left clicking would always be for hide/show.
So whether you see an eye or a lock, if you left-click on it, it would blank out and be hidden.
If it was blank, then doing a left-click will show it and make an eye or a lock appear.
Then as far as setting the lock/unlock state, I was thinking of putting that on a button in a pop-out menu. But there could also be a key combo that would do it as well, like Ctrl+click like you mention.
I was also thinking that right-click on a lock could be unlock rather than doing the group visibility thing, but maybe that is not so good.
But the general idea is to enable having a lock state but without it adding such a high impact to the UI as a whole additional column would bring. Locking is not switched around as frequently so it would be good to have it but in some kind of subordinate way.
2470.78 In reply to 2470.77
>...left clicking would always be for hide/show.
This would be quite direct and clean.
About locking, it can be interesting to have two different types of locking, layers and objects.
Since the objects are automatically highlited when we move the mouse over them or their parts,
a script step could allow locking with a keypress on "mouse over".
Moving objects between layers
I just thought I'd mention something I quite like in Blender :
When the user wants to move an object to another layer,
he presses the "M" key,
a pop-up layer grid appears,
and the user clicks on the destination layer (if the destination layer is hidden, the object disappears).
Please feel free to mention if all this "outsider thinking" becomes annoying
(if it seems to bring you back in too basic things).
- Michel
2470.79 In reply to 2470.77
Change the text to red (or greyed out) if the layer is locked? Keeps it separate from the hide/show side of things
But if you want to use the icon then for this control I think you you need more states of icon.
So you need:
Hidden but not locked - blank
Shown but not locked - eye
Hidden and locked - blank with small lock symbol in corner
Shown and locked - eye with small lock symbol in corner
I've used this technique before in a number of icons - works pretty well
Normal/right click can hide and show, CNTRL + normal/right click locks/unlocks. I would also suggest having have both hide and lock commands on the flyout too for those that just want to use mouse or tablet without resorting to the keyboard
Another tuppence worth from me for your consideration ;-)
Tony
(aka HamSoles)
2470.80 In reply to 2470.78
Hi Michel,
Yeah, I also want to have a "Lock" command on the Edit toolbar right next to where "Hide" is currently located.
That will give you a way to Lock the currently selected objects, or unlock them if there is no selection, same as how the Hide command currently works for hide/show.
It will be possible to set up a keyboard shortcut for that same as how it is possible to do one for hiding currently.
Then the basic idea is that the scene browser will allow you to apply that same kind of thing to some predefined set of objects rather than only to the current selection.
re: Moving objects between layers
That sounds like a pretty good method... The way I was figuring on doing it was pretty similar, with a pop-up panel on the object properties pane that lets you set the "Style" property of the currently selected objects, like this:
I think it will also be possible to trigger that UI to be shown with a keyboard shortcut as well, we'll see...
2470.81 In reply to 2470.79
Hi Tony,
> So you need:
That sounds like it would work well.
The only thing is that I'm not so sure yet if you really will care that much about knowing when something is "hidden but locked".
That's why I was thinking of making both "hidden and locked" as well as "hidden and unlocked" just be blank. That lets me have just a big lock icon for the "locked and visible" state which may stand out a bit more as compared to a lock in the corner type thing.
I think I'm going to give this "3 visual state" thing a try at first and just see how it works in practice. If that does not work out then I can switch to a 4 visual state type thing like you are describing.
Ok, some concepts are starting to come together a lot more.
So the overall idea for the browser is to let you do some common actions like hide, show, select, ... on a set of objects.
This will include groups that you have specifically defined, but also some other kinds of "built in" sets so you can have one place to go (with a common UI) for doing things like:
Select all curves
Hide everything except solids
Hide objects that have style = Red
Etc...
The browser has a few different categories for some of these different kinds of sets:
Groups will be containers that you can define that can hold a list of objects or other sub-groups.
Objects shows named objects - if you assign a name to an object or multiple objects, that name will show up under this section to allow you to hide/show/select it.
Types allows you to target all objects of a specific type, like all curve objects, or all solid objects, again with all the same kind of controls like hide/show/select/whatever:
Styles allows you to target all objects that have been assigned a particular visual style. Like for example if you want to hide all objects that have been assigned the style "Red", you can do that in this section. Again with the exact same controls as the other sections for hide/show/etc...
So the idea overall is that this is a "one stop shopping" place for dealing with management operations on sets of objects, with various different kinds of sets.
There is flexibility so you can work in different ways if you want to, like if you want to primarily base your organization off of the object's visual color, you can work with the Styles section (this will then be fairly similar to traditional CAD layers). If you want to just be able to get back to one particular object easily later on, then give that object a name and use the Objects section. If you want to do some more complex hierarchies, then you can set up groups. You can use any of these strategies by themselves or mix them together.
Then additionally being able to target specific object types like "hide all curves" will also use the same UI for hiding other sets... I think you'll even be able to do things like "hide all the curves that are not currently selected" in a natural way with this.
So anyway, that's where I am at currently with the overall strategy. It seems to be coming together in a coherent way now.
Seems pertinent...so...
Wait and see :)
EDITED: 14 Mar 2009 by PILOU
2470.84 In reply to 2470.83
Looking good so far Michael.
Tony
(aka HamSoles)
2470.85
Do you have an idea how resolve things like:
Drawing a curve when 'hide curves' in active ? In max for example you don't see what you are drawing in that case, and well, it's a bit disturbing ^^
2470.86 In reply to 2470.82
Lookin good Billy Ray!
2470.87 In reply to 2470.85
Hi PaQ,
The way that I'm currently planning for these things to work is that they are actions that you perform, rather than a persistent mode.
So for instance if you go to hide curves, it will be the same as if you had selected all the curves in your model and then hit Hide (using the current Hide tool from MoI v1 I mean). It won't be a permanent "sticky" mode.
That would be the same behavior for all those kinds of things - groups, named objects, types, and styles.
Otherwise if these were persistent modes, there would be all sorts of conflicts that would arise (aside from having some strange effects like you mention), like what if you had set curves to be off, but then you have a named object that is a curve and then you turn it on using the "named object" UI? One thing would be saying "turn it off" and another thing would be saying "turn it on"... I would have to have some kind of hierarchy of one of those states "winning" out over the other.
By doing things as an immediate action instead it avoids these kinds of conflicts.
There will probably be some kinds of situations where a "sticky mode" could be useful, but it is just so much more complicated to have that. The "immediate action" method I think will work out to be more simple overall and it makes it easier to have many different categories to work with, that kind of flexibility should hopefully be useful. We'll have to see how it works out though.
2470.88 In reply to 2470.87
Seems to be a good solution indeed :)
EDITED: 16 Mar 2009 by PAQ
2470.89
Been away for a while and just trawled through this lengthly thread! Too much text and not enough pictures!!;-) It's looking great can't wait to have a spin. I think the eye logo is a good choice and looks good. i think most of my thoughts/questions have already been covered and it all looks nice and flexible, this one might have slipped through though... will there be an option to isolate a group that can be worked on in isolation? What would be even better would be the greying out of the rest of the model which would become inactive but still there as a reference for guide lines etc. But maybe that might be a bridge too far just now.
Will instances still be a V3 feature or are you on a roll?..............
EDIT: Also can I make a cheeky request for the exportation of groups/styles for poly models be put at the top of the priority list for the next beta - and can that beta just consist of that feature!!! For me at least this is a major stumbling block for large production work.
2470.90 In reply to 2470.89
Hi Rob, thanks for your feedback!
> on in isolation?
Yup, the idea is to do that with a right-click on the eye icon.
A left-click on an eye will just turn on or off that particular item, but a right click will hide everything else except that item, and a second right-click on it again later will turn all things back on again.
> too far just now.
That will be called "locking", and I do want to have that but it probably won't be in this next beta with the first round of this stuff in it.
Not on quite that much of a roll! ;) That's going to take quite a bit of work to make instances function well, so I don't think it will be possible to get that in for v2.
I sort of need to the UI nailed down first so that I know how things should behave in MoI. Once that behavior is worked out then after that I can figure out how to map the mechanisms in MoI to what is supported in a particular file format.
So probably the next beta won't have this part working yet, but it will be happening before v2 is finished for sure.
2470.91 In reply to 2470.82
Looking great!
Maybe small icons before 'curves', 'surfaces' could be intuitive.
It could be the same icons than in the construct tabs but smaller, like the color swatches.
Marc
2470.92 In reply to 2470.91
Hi Marc,
It would be cool, but there is only a very small space available there for the icons, they need to fit within about 16 pixels of height...
I'm not very optimistic about being able to shrink those images down to that small of a level and still have them look good.
Some more progress on the scene browser styles section:
When some objects of a given category are mixed with some hidden and some shown, you'll get a "mixed status" half-eye which you can see there for Red in this case.
If there are no objects that belong in a particular category, the text for that category will be grayed out. This indicates that you can't click to hide/show objects on that one since there are no objects associated with that slot.
The ring around the outside of the Magenta swatch indicates that is the "active style" - that is the style that is assigned to brand new objects that you draw.
If you have objects selected, you can click on the swatch to assign those objects to have that style. If nothing is selected and you click on a swatch it will make that swatch the active style, and if you right-click on a swatch it will become the active style regardless of whether objects are selected or not.
I've got right-click on the eye working for "isolate" mode (hide everything else except that slot) and it is feeling great!
Next up is selection (and isolate selection, and deselection), which right now I think will happen by clicking on the text label.
Then after that maybe some more stuff on a drop-down menu, I think the way the dropdown menu can work is that when you move your mouse over the line, a drop-down arrow will appear on the far right side and you'll be able to click there to pop open a menu.
Anyway, it seems to be coming along quite well with a lot of functionality embedded in a streamlined UI.
2470.94 In reply to 2470.93
And maybe you can have an another option if the "half eye" is left or right
2470.95 In reply to 2470.94
Hi Pilou, is the half being on the left or right an important thing for you?
I don't think there will be a checkbox option for that, but the "half eye" comes from an image named VisibleMixed.png, which like all the other icons in MoI is in the \ui subfolder.
So if you want to have the other half instead, you can edit that PNG file in an image processing program however you would like...
Show messages:  1-15  16-35  36-55  56-75  76-95  96-115  116-135  136-141
