Scene browser progress
 1-17  …  98-117  118-137  138-141
2470.138 In reply to 2470.137
Hi yannada, well the main tools will be in the same location that they used to be before there was a scene browser. So it is not like you will be moving any further than you have had to previously.
Some things like the main window close / minimize / restore controls currently live in the side pane, it would maybe be a little odd to move those away from the window corner. So I'd probably have to do something about that in order to have such a mode.
Also I expect that it will not be that unusual to want to hide or show the browser fairly often (especially on lower resolution displays), and it seems like it would be kind of weird to have the main tools shift around every time you did that.
At any rate, you'll be able to give it a try, I'll tell you how to edit the MainWindowLayout.xml file to do it, you just move one line up to higher in the file so that it docks first before the side pane is docked.
2470.139 In reply to 2470.138
cool... edit the MainWindowLayout.xml it wiil do the job (if needed)
2470.140 In reply to 2470.72
Hi Marc, previously you asked about swiping:
> I don't know if this has been said before but it would be nice
> if you could click+hold and then slide your mouse over multiple
> eye icons to turn them on/off ion a sweep motion.
Earlier I didn't think I would have this at first, but I've managed to add it in.
The way it works is that it remembers whether the initial clicked item resulted in a hide or a show, and when you swipe with the mouse held down, it will apply that same result to all the swiped items.
Does that make sense rather than trying to invert every item you swipe over? Doing an invert seems less of a predictable thing when there are a mixture of states, rather than applying the same thing to all the swiped items.
2470.141 In reply to 2470.140
Hi Michael, great!
It seems to be a practical behavior this way!
I also think inverting states would be a less convenient event.
I imagine a couple of laps on the race track will validate all this.
Marc
Show messages:  1-17  …  78-97  98-117  118-137  138-141
