Unexpected result Sweep
All  1-2  3-5
2468.3 In reply to 2468.2
Hi blend3d,
It looks to me that you used a profile and two cirlce objects.
That will certainly work.
If you download the 3dm file you will see in the front view,
that the big curve is made up by 3 arcs and 3 fillets
I did resolve the problem afterwards, by reconstructing the
big curve with controlpoints and Curve Through Points.
Thanks for the reply,
EDITED: 8 Mar 2009 by PAOLOLOBBIA
Size: 21.6 KB, Downloaded: 46 times, Dimensions: 747x644px
2468.4 In reply to 2468.1
Hi Paolo, right now sweep in MoI tends to be sensitive to uneven spacing of the rail's control points. The profile's has some control points closer together in that area, that makes the sweep be kind of bunched together in that area as well.
I am planning on fixing this up in v2 when I get a chance to do some work on sweep, I'll use your file as another example of the problem to work on, thanks for posting it!
2468.5 In reply to 2468.3
Hi Paolo,
Sorry I missed the file in your post, I had thought the rails were circles looking at the picture.
- Blend3d
Show messages: All  1-2  3-5
