YAUP (Yet Another Union Problem)
All  1-4  5-9
2466.5 In reply to 2466.3
> Those can probably be repaired, I'll give a try in a bit.
I'll still take a look later, but it looks like Burr has you covered already, thanks Burr!
2466.6 In reply to 2466.1
Your surfaces are a bit of a mess....try re-constructing the pipes using cylinders/spheres (watch the seam lines & how they might intersect with the main body) then boolean. Alternatively, sketch a curve on Centreline and fillet edges slightly bigger than your pipe radius and use sweep1...thats how it would be made for real anyway ;-)
HTH
:-( cannot attach my file
EDITED: 7 Mar 2009 by KARTER
2466.7
Thanks for the help, guys.
How odd that the pipes were freaky. They were vanilla sweeps of a simple circle over relatively tame paths.
2466.8 In reply to 2466.6
Hey carter thanks. I used square line segments and then filled the corners with spheres. Silly me.
Nice pipe!
Burr
2466.9 In reply to 2466.7
Hi Todd - you can run into problems like this with sweep where you have a bend in your path where your profile curve has a larger size (larger distance away from the path) than the radius of the bend.
Here's an illustration of this kind of thing:
Notice how when trying to sweep the line above along the curved path, that because the line is longer than the radius of the bend, it gets all bunched up in that area? That's a similar kind of thing as what you're running into here.
This same kind of problem can apply to several different functions that work by keeping things a constant distance or perpendicular arrangement from a path curve, including Sweep, Offset, and Fillet.
Here's the similar kind of area from your pipe:
So that is going to end up doing a sweep of that large circle around that small arc, like this:
Or as viewed in 3D:
As that circle sort of marches along that path, it will make things like this:
As you get more of them, you can see how that kind of a shape will be generated:
Instead of doing a circle there, you may need to do something like just the "outside" 180 degree arc so that you can avoid that self-overlapping to the inside part.
Show messages: All  1-4  5-9
