Wish: some default keyboard "shortcuts"
All  1-2  3-5
2459.3 In reply to 2459.1
Oh also - one keyboard shortcut that does work currently with the meshing dialog is Esc key for cancel.
It will probably be easy for me to do at least Enter for OK, and maybe Tab to go between input fields, I'll give it a try tomorrow.
2459.4 In reply to 2459.1
Hi Micha, I've made some improvements in the next v2 beta for some additional keyboard handling with the mesh dialog.
If you have the dialog in its expanded state, you will be able to type in some numbers directly without clicking and your numbers and the keyboard focus will automatically go to the "Angle:" field.
So for instance after the dialog is launched, you can then immediately type 30 <enter> (with no mouse clicks) to set the angle to 30.
Also you will be able to use Tab to move focus between the numeric input fields (Angle, Divide larger than, Avoid smaller than, and Aspect ratio limit).
You'll also be able to use Enter as a shortcut for pressing the "OK" button.
If you have focus on an input field, the first Enter keystroke will commit that field, and then a second Enter will work as a shortcut for OK.
Basically the Meshing options dialog will now behave in a consistent manner with the regular command options area for commands like Fillet or Rectangle which I described above in this thread.
2459.5 In reply to 2459.4
Thank you. :)
Show messages: All  1-2  3-5
