Meshing ... tests and wishes
 1-5  6-25  26-45  46-65  66-69
2451.6 In reply to 2451.1
Hi Micha,
> (2) mesh #1
> Here I wonder me, that at the big main surface no quads are
> created. Best would be, if the quad edges would match with
> the edges of the rounded edge at the sides.
The reason for this will become more clear if you switch temporarily to Output:n-gons to see the n-gon structure, which looks like this:
During the process of meshing, MoI forms n-gons, which start out as quads that follow the UV structure of the surface, and then can turn into n-gons where they hit trim boundaries or also where they connect to the separate UV structure of an adjacent surface.
If you go into Rhino and set that object to display with a high number of isoparms, you can see this:
Notice how the isoparms for the fillet do not completely align with the other surface? That's because they have a different kind of UV space to each of them, that's one reason why they can generate some different initial UV grids.
I think it is going to be possible for me to do some work in the future to try and form the initial UV quads of a fillet after the "main" surfaces have been done and in some situations it may be possible for me to make a better initial structure for the fillet that matches an adjacent surface, but probably only when there is a plane to one side of the fillet since matching to pressure from multiple sides of curved surfaces is probably not going to work.
This is not going to be a completely easy thing to try to improve, so it probably won't happen very soon but at some point in the future.
2451.7 In reply to 2451.1
Hi Micha,
> (3) rounded cube
> I'm not sure it's possible, but it could be nice, if all rounded
> edges of this cube would show the clean quad polygons.
Usually rounded cubes like that should be getting nice aligned quads like you want.
Was that a rounded cube that you created in MoI, or was it an imported one?
It looks like this rounded cube model was not included in your attachments, could you please post it so I can test with it over here? Also do you see this happen at any kind of meshing parameters or is it only at a specific setting?
Here is a quick example of this kind of rounded box created in MoI and then exported using Quads & Triangles, I think it has the kind of structure you are asking for?
2451.8 In reply to 2451.2
> (4) mesh #2
> This is an object, that cause strong artefacts per Rhino mesher.
> At MOI3D it looks much better, but maybe it's possible that the
> triangles can be avoided.
It looks like the object has a pretty complex trimming curve in some of its edges, which is having an effect on the mesh generation.
Here I have duplicated the highlighted edge off to the side and turned on its control points:
Compare that to the control points of the surface itself:
As you can see, the edge has a complex curve and it does not match the simple structure of the surface - that edge is not an isoparm of the surface even though it looks like it probably could be.
Edges have a big impact on meshing since to make a "watertight" mesh, the mesher has to produce additional points along each edge. A complex edge like that is going make it harder for pieces to get lined up and handled in the most simple way.
I've attached an updated version of your object here as mesh#2_quads.3dm - to simplify the edges of this shape, I took your object, used Edit/Separate to break it into individual surfaces, then selected all the edges of those surfaces and did a Delete to "untrim" them and get the natural surface isoparms as a new simple trimming boundary, and then rejoined.
With this better edge structure you can now get all quads when you export from MoI.
In general if you have high complexity edge curves or other irregularites in the geometry itself, it will often have some kind of an impact on not making the most ideal meshes from it as well.
2451.9 In reply to 2451.1
Hi Micha,
> (5) mesh #3
> This is a plane, where I moved some control points at Rhino.
> The direct retry to mesh it cause some strange effects,
I can't seem to reproduce this problem, did you possibly attach the version after you have moved additional points where it works ok?
Also can you describe some more about the strange effects - is it the overly dense part, or do you not like the centroid style triangulation of n-gons - if it is the latter please refer to that previous message I posted for how you can disable that.
Otherwise if this is the fixed version that you posted here, can you please post the original version that has the problem in it, and please let me know if it needs any certain parameters to see the problem if it doesn't happen with the default parameters.
2451.10 In reply to 2451.2
Hi Micha,
> (6) mesh #4
> The Rhino mesher create big kinks at this cylindrical surfaces.
> It is an old test object, but if I remember me right, it was
> from a project STEP file.
No big kinks in MoI, right? So that is good! :)
Is your concern about getting only quads on this? If you do you'll probably need to simplify the edge structure of the shape, if you select the edges you can see that the boundary of those cylinder parts is split up into some additional edge segments rather than it having only a simple edge structure.
I've attached a tuned up version which will now generate all quads.
I did the tuneup by selecting the object, running "ShrinkTrimmedSrf" on it (which you have to set up with a keyboard shortcut to use in MoI, there is not currently a button for it), then Edit/Separate, then Select all edges, then Delete to untrim, then joined again.
The same comment applies as from that previous example - if the shape is set up to be overly complex like in this case with trim curves split up into more pieces than necessary, then that can often have some kind of impact on meshing as well.
If you have clean and simple geometry and topology it will help to generate clean and simple mesh results as well.
Complex geometry and topology will tend to make the mesh somewhat more complex as well.
2451.11 In reply to 2451.2
Hi Micha,
> (7) mesh #5
> Artefacts - that's new. ;) (angle 55)
This one is a bug! :) But it happens to be one that I've already fixed up for the next v2 beta.
It's a bug that got introduced with some of the changes to do faster meshing in the most recent v2 beta.
You can use MoI V1 right now for this one particular object to avoid the bug (just be patient while using v1, it is a lot slower of course).
Anyway the next v2 beta release will generate a proper mesh for this case the same as v1 did.
> But also the most cylindrical surfaces dosn't show a regular
> mesh of quads (finer mesh without artefact).
Basically all the same stuff I mentioned previously applies - the fillets in this case are between 2 curved objects, the fillets cause trimming edges that are not isoparms, they are curved. For example this fragment:
Notice how the trimming boundary there is not flat, it is curved? That means that the trimming boundary can have additional refinement points on it as well, same as the refinement for surfaces that I described earlier. When edges are refined it will generate n-gons rather than quads.
Additionally notice how the edges are in multiple segments...
2451.12 In reply to 2451.2
Hi Micha,
> (8) mesh #6
> At Rhino the opening in the middle is complete closed by a
> big artefact, at MOI3D the general shape looks a little bit
> strange at the sides (screenshot).
Are you using a very coarse meshing angle for that particular screenshot result?
When I tried your model at normal mesh densities it was looking fine...
At much coarser mesh densities the kinds of things that you show there are not uncommon and can just be a normal part of getting both a coarse edge boundary and a coarse surface quad density.
Generally something that is curved by quite a bit will look a bit strange when using only a small number of jagged polygons to represent it. Particularly if the interior surface happened to get something like no divisions on it while the edges got one division or something like that.
2451.13 In reply to 2451.3
Hi Micha,
> (9) rotation object <...>
> Interesting is, that the Rhino command _QuadrangulateMesh can
> be used to eliminate some triangles. I have the feeling, if
> _QuadrangulateMesh works, than the mesher created to much
> triangles, more than necessary.
Yeah it does look like those ones should be quads, I'll see if I can figure out what is happening there.
> Here it could be nice, if polygons around the torus profil
> could be in the same angle. At the moment the inner
> polygons are finer than expected. This could be interesting
> for using the mesh per T-Spline or Sub-D modeller.
This one has an easy workaround - it looks like it is only happening at a few particular very rough angles. If you adjust your angle slightly to 57, you should get the same mesh structure but without that one extra refinement:
When you have an angle value that happens to be right near a "boundary zone", it can pretty easily lead to this kind of irregularity. If you want to reduce refinements just a small adjustment in your angle can eliminate it. The mesher is not really very focused on doing such coarse things, I mean it will work but you can run into some slightly odd things at such extreme angles.
Message 2451.14 deleted 28 Feb 2009 by BURRMAN
Hi Burr,
> Wouldnt the avoid smaller than option fix this? or is
> that in the other direction.
It can help to reduce subdivisions, but more often on a more regular density mesh than one that is already being generated at a very coarse angle.
Basically the "Avoid smaller than" takes a distance, and any polygon that is smaller than that distance will instead shift to use a coarse angle of like 35 degrees rather than the regular angle.
This makes it possible for something like a tiny curved fillet in your model to get meshed at 35 degrees rather than say 5 degrees for everything else.
But if you are already doing everything at 50 degrees then it won't make any difference.
2451.16 In reply to 2451.3
Hi Micha,
Some good news on this one, I was able to make a minor tune-up to preserve more quads in this situation.
In the next v2 beta this one will now get all quads, here is a screenshot of what it will look like:
2451.17 In reply to 2451.16
(3) rounded cube
The object I used is a Rhino object (copy&paste to MOI) and I attach it now. Could be nice, if the mesh could be same, dosn't matter it is a STEP import, a Rhino copy&paste or a MOI3D creation. ;)
(4) mesh #2
This object is a "o" from a Text object "Rhino". Interesting for me is, that you talk about independent edges and surfaces. I thought a surface or polysurface has edges, but you extract and delete them. That's I don't understand.
"I've attached an updated version of your object here as mesh#2_quads.3dm - to simplify the edges of this shape, I took your object, used Edit/Separate to break it into individual surfaces, then selected all the edges of those surfaces and did a Delete to "untrim" them and get the natural surface isoparms as a new simple trimming boundary, and then rejoined."
Could it be possible, that this is internal automatic done for meshing? Or can I do something at Rhino befor export an object to MOI? Are the edges needed for meshing? Is at MOI at command to select all edges?
(5) mesh #3
I attach the original surface, now it should be buggy. ;)
(6) mesh #4
Seems to be the same problem like at (4) and I don't understand it, why edges are independent from the surfaces and how to delete edges. I would like to avoid the effect per Rhino script befor I export the object to MOI. I afraid, at complex models the "separate-edge-delete-join" method could be a problem.
(7) I'm curious for the next beta. :)
(8) I used an angle of 35°. It's the "o" from a Rhino text object with a round.
This screenshot above was done befor I changed the CentroidTriangulation option at the ini. (Sidenote: the Rhino mesher create this overhanging peaks too.)
Interesting - now I tested the object again and it looks much better, also at a rawer angle of 55° - great! In regard to the easy usage of MOI it could be good, if the bad look of first screenshot could be avoided allways. ;)
Two other things to this - at Rhino I found, that some triangles can be converted to quads (maybe this is fixed in your internal version like you wrote at (9)) and could it be possible, that the CentroidTriangulation option is part of the general meshing parameters?
(9) :)
... one thought from me, as I bought MOI3D some days befor was, maybe it's a good time now for tests and improvement requests. :)
Thank you.
EDITED: 1 Mar 2009 by MICHA
2451.18 In reply to 2451.17
WOW, I increase the angle just for fun and the mesher dosn't create crap (case (8) - the Rhino "o" with rounds), it looks like it should look, also at this extrem raw angle. I'm impressed!
... but I found, that the result is not stable at all angle values - maybe it's possible that the mesher can be refined to avoid this effect. But's good to know, that it help to fine adjust the angle value to avoid some sideeffects.
2451.19
Micha. You know all these type of shapes can be easily modeled in any poly modeler. You could also easily create directly in Rhino using combinations of rail revolve or sweep with polylines, with Surface Creasing plugin, then extract the control polygon. Weld the mesh, and send out ready for subd...
jonah
2451.20 In reply to 2451.19
Thanks, the easy examples are examples only. I think, if the easy example works, than complex models should be good meshed too. Most important for complex scenes, where the polycount must be keeped low, but good looking - for example for rendering train / air plane interiors or large ships with many details.
2451.21 In reply to 2451.18
Hi Micha,
:) It depends a bit on the particular situation though, if you end up with a surface that has only one polygon for the surface part, but an edge gets a refinement in the middle of it, that refined point of the edge will be placed at the actual point on the curved edge's midpoint which is then a far distance away from the single polygon that is approximating the surface. That then makes for a kind of very warped polygon.
It basically causes a single polygon to have a very non-planar shape, which makes for somewhat odd looking polygons.
> this effect
I guess it would be possible, but it would probably need a special "low polygon" mode that tried to do things in a special way that did not follow the regular method used for normal meshing. Unfortunately that would probably take a fair amount of work so it is not too likely that I will be able to accomplish that anytime too soon. I'd also worry about cluttering up the UI with specialized tools that were only useful to a very special kind of case, that is not so good because it means that the main tools become more complicated to use for everyone and the only benefit is to a very small area of work. That's how adding some things can actually end up with an overall negative effect rather than being an overall benefit to a larger group of users.
Some more notes on the strange-looking result:
Under normal circumstances it is important to be able to have an edge refined with points added to it to an additional amount beyond the surface that it is on, because an edge can easily be curved in shape a lot more than the surface.
Here is a basic example - here I have a plane so the surface is not curved at all, but meanwhile the trim edges of the surface have a very curved shape:
If I did not refine edges to have additional points, then a shape like this would end up with a mesh looking like this:
Which as you can see would not be a good result for the most regular meshing cases such as regular rendering, etc...
Basically for extremely low polygon shapes like you're experimenting with here, I would recommend building those using the tools in a polygon modeler like jonah mentioned, that is a toolset that is specifically designed for that purpose.
The case you are showing here is starting with a very curved shape, that's just not really the best starting point in general if you want an extremely angular result, it is better to use a toolset that is specifically designed for that kind of a thing to get the best results.
2451.22 In reply to 2451.20
If polygon count is so crucial, I dont think you need fillet on your models, it will increase the poly count a lot.
If fillets are important, you should try to use a smaller meshing angle (12-20), and use the 'avoid smaller than' option to reduce the number of polys. You'll have a much better visual/polycount ratio than just rising the meshing angle so high.
2451.23 In reply to 2451.17
Hi Micha,
> creation. ;)
That would be cool, I agree! But a rounded box can be defined in many different ways, and in order to get one to mesh with all quads the "underlying" surface of the rounded part must be aligned with the other pieces.
The model that you have posted here is not configured in that way at all, if you use Edit/Separate on it to break it into surfaces and then turn on control points for a corner, you can see the surface for it is actually set up like this:
Notice how the surface control points of that corner piece are not aligned with the trim edges?
That corner is defined as a kind of rotated sub-region trimmed out from a larger sphere portion, the sphere is oriented like this:
The problem here is that the UV layout of that sphere (for instance if you were to look at its isoparm grid) does not have any kind of alignment with those edges. Here is dense mesh of just the sphere where you can see how the trim edges collide with the natural surface UV grid at an odd angle:
Because of this lack of alignment, you won't get simple quads from that kind of corner patch.
If you do a similar examination of the rounded box built in MoI, you will see this kind of structure instead:
Notice how the corner pieces there have a natural alignment between the surface and its trim edges? That kind of more simple structure provides the alignment between the surfaces that is necessary to get simple pure quad mesh generation.
So again, don't just assume that every rounded box is constructed in the same way! :) It is possible for some to have a construction method where surfaces do not share natural edges and that will prevent simple mesh output from that kind of stuff.
2451.24 In reply to 2451.17
Hi Micha,
quote:
(4) mesh #2
Yes - every surface or polysurface has edges to it - but part of the definition of an edge is a 3D curve that gives the shape of the edge (there is also a UV curve that is in the UV space of the surface). In this case that 3D edge curve is pretty complex, just take a look at the screenshot which I will show here again:
That edge has gone through some kind of "fitting process" to calculate it as an approximation, maybe as an intersection between 2 surfaces or something like that.
Anyway, as you can see from the number of points in it, the 3D edge curve is not as simple and clean as it could possibly be, to get a better mesh I removed the existing 3D edge curve (by "untrimming") which forced a new one to be calculated from the underlying surface. The new 3D edge curve is more simple in structure and exactly matches the underlying surface, making it a more simple structure overall and helping to build a better quality mesh.
Unfortunately it is kind of tough, often times you need a kind of human intelligence to analyze the shape and see what parts can be simplified. It can be difficult to replicate this with a kind of artifical intelligence.
It's also possible that in different situations this kind of process can change the shape of the object slightly. I kind of worry a bit about doing things automatically that change the shape, it is another area that can require judgement.
Possibly either "untrim", or "RebuildEdges" in Rhino could be used for a similar process.
Edges are definitely used in meshing, without processing edges then you would only ever have meshes that used the "underlying surface" parts of objects and not any trimmed areas which are often formed by booleans, etc...
Edges that are messy or more complex than needed, or wiggly, etc... can introduce complexity into the generated mesh, same as if the surfaces are more complex than needed or wiggly, ...
You just first select one edge with the "drill-down" click (when you click a second time on an object), then use Ctrl+A to select all.
That is that we can name a full answer :)
Show messages:  1-5  6-25  26-45  46-65  66-69
