Export curves
 1-8  9-28  29-31
2446.9 In reply to 2446.8
> Blender accepts curves as obj format!
> But Moi don't export it ;)
That's cool, but I think Alexito was asking about loading curves into Bryce and not Blender?
Does Bryce support importing curves in obj format?
2446.10 In reply to 2446.9
No Michael Bryce doesn't support importing curves in obj format .
But you said that MoI can export curves to 3DM and Bryce can Import 3DMF
is it the same thing or is far from it ?
Bryce can Import a lot of formats I will give you the list maybe we will find something.. ;)
Thank you Michael and Pilou
here it is :
Bryce can import objects saved to the following file formats.
TrueSpace (.cob) Versions up to 4.0 are supported. Material properties are supported.
VideoScape (.vsa) All versions are fully supported.
VRML1 (.wrl) Imports all properties relevant to Bryce, including camera, light, and surface and material textures.
LightWave (.lwo or .lws) Both objects and scenes are supported. The camera, lights, and all objects (with material information) are imported. Versions 6 and up are not supported.
Heightfield (.hf) Used to import descriptions of heightfields (terrains).
USGS DEM (.dem) All forms of DEM files are supported.
USGS SDTS (.ddf) This format is the new USGS format which will replace DEM files.
Portable Greyscale Map (.pgm) Used to import descriptions of heightfields (terrains).
3d Studio® Objects (.3ds)
3DMF (.3mf)
AutoCad® (.dfx)
Direct 3D (.x)
Wavefront (.obj)
WCS Elev (.elev)
WorldToolKit® (.nff)
EDITED: 26 Feb 2009 by ALEXITO
2446.11 In reply to 2446.10
I had yet seen the Bryce formats but seems there are no possibilities!
2446.12 In reply to 2446.10
Bryce does not work with curves. Notice no curve tools. if the curves you want can be planar, then you can trick it by extruding your curves in Moi, selecting not to cap, then export the obj. Then in Bryce, give it a Y attribute of 0.
Curve.
2446.13 In reply to 2446.10
Hi Alexito,
Nope, those are totally different.
3DM is the Rhino file format.
3DMF is the file format from the old Apple Macintosh Quick Draw 3D system (Wikipedia link), which was abandoned by Apple about 10 years ago so it is a very rarely used format in general.
2446.14 In reply to 2446.10
Hi Alexito, nearly all of those formats that you list there do not any capability provided within the format to hold curves.
Those are mostly set up to only contain polygon mesh objects.
One exception in your list there is DXF - however DXF can contain a lot of various types of objects including polygon mesh objects as well as things like lines, curves, circles, arcs, .... But it is not unusual for programs that are designed to only work with polygon mesh data to skip all these other kinds of things and only read polygon mesh objects that can be found in a DXF file, most likely Bryce is set up like that.
If you'd like to try, I do have a DXF converter that you can download from here:
http://moi3d.com/wiki/Resources#3dmCurves2DXF_converter
That is a small stand-alone converter program that can take a 3DM file saved from MoI with curves in it, and then generate a DXF file with curves in it.
You might give that a try, but my guess is that Bryce will not read the entire DXF file and will just skip the curves that are in it. But it is probably worth trying out.
Basically if a program is not designed to work on curves, then it is pretty hard to import curves into it, that's pretty much what you are dealing with I think.
What is the interest to use Bryce for modeling?
It's very difficult !
2446.16 In reply to 2446.15
Nice Trick BurrMan but for what I want it will be too difficult to do.
Yeah you right Michael Bryce skip the curves and even skip the surfaces, in fact Nothing appears in Bryce with my 3dm
file converted in DFX; Burrman is right I think It's simply because there is no curves in Bryce.
I'm not interseted to modeling in Bryce but I want a render with my planes and my curves.
I post you an exemple, it will be more clear
2446.17 In reply to 2446.16
can you post your 3Dm file of this?
2446.18 In reply to 2446.17
ok here it is ;)
2446.19 In reply to 2446.18
hum hum that crash the programm!
email crash is send to michael :)
Don't change your file before Michael look at!
PS Next time compress the file for the size and time of transfert ;)
2446.20 In reply to 2446.16
I didnt look at the crashing 3dm file but the picture you posted looks like all planar surfaces which will export out as obj into bryce. The curves no, but you cant render a curve anyway.
2446.21 In reply to 2446.20
yes but It was my question : render the curves.
I was thinking someone could have a trick !
2446.22 In reply to 2446.19
It appears that the file that causes the crash is possibly corrupted, maybe it did not upload properly or something like that...
It also crashes when trying to load into Rhino v3 or v4.
The crash is happening inside of the OpenNURBS library code for reading 3DM files. I'll take a look to see if I can tune it up to skip the corrupted areas.
2446.23 In reply to 2446.22
Ok I repost it
2446.24 In reply to 2446.23
Hi Alexito,
> Ok I repost it
That new .zip file is corrupted as well (this time the unzipper program reports the corruption), it looks like your uploads are incomplete or something like that?
Do you often have problems uploading things, or is this something that is only happening to you on the MoI forum?
2446.25 In reply to 2446.16
Hi Alexito,
Sorry it is still not clear to me exactly what you are trying to do even after looking at your example.
Is it that you want the edges of your polygons to be rendered in addition to the shaded polygons themselves? Like a "wireframe view" being displayed at the edges of your surfaces?
If so then that is somewhat different than rendering "curves".
Normally when you say "curves", that actually means a specific thing in MoI, like curves that are drawn using Draw curve / Freeform, things like that. Those are independent objects, edge curves that are part of surfaces are slightly different.
That previous DXF converter program that I mentioned is only for converting independent "curve objects" such as a drawn line or freeform curve, into a DXF file, it will not try to grab edges of surfaces.
At any rate, if Bryce does not render curves or do wireframes then it probably means that you just can't use Bryce to get what you need. If you need to do something that Bryce does not do, you will need to use a different rendering program instead.
You may want to also check in a Bryce discussion forum as well though, maybe there are other kinds of workarounds or other things that a community of Bryce users could tell you about to help you solve your problem.
2446.26 In reply to 2446.24
Are you using a Dialup connection to the internet?
2446.27 In reply to 2446.21
Just another trick.
Nurbs Curves dont render so you have to do some kind of trick. You could give your curve some kind of "Solid" in MoI which could represent a curve in your polymodeler.
So I take my curve in MoI and sweep a .05 circle with it then export the OBJ
A curve in Bryce.
2446.28 In reply to 2446.27
Yes I have a low connection for the moment.
Yes Michael I want the edges of my polygons to be rendered in addition to the shaded polygons themselves.
BurrMan I Had the same idea but with my polygons the angles are broken; but it is close of what I want.
In fact what I have done in Bryce is ungroup my object and reduce the size of it that make appears the edges,
because it reduce all the parts separatly ( I don't know if it's clear ).
Sorry because my english is not very good.
Show messages:  1-8  9-28  29-31
