system decimal display
 1  2-21  22-38
2445.22 In reply to 2445.21
Hi Burr,
> Well, thats what you gave me now.
Not quite exactly - for example even with these updates above if you set your number of decimal places display to be 4 decimal places (under Options / General / Decimal display), and then create a rectangle and enter in a width of height of 5.45 for it, it will be displayed like this currently:
That's because MoI currently strips out any trailing zeros at the end of a numeric display just to try and make the display a little more compact and simple where possible.
But I can add an option to enable trailing zeros, which if enabled would then make a rectangle with 5.45 width and height display like this when 4 decimal places is set for the display:
When that option would be set, that may help to clarify the precision of any particular number you are looking at since it would not be shortened with the ending zeros removed if it was exact. That would then hopefully give you the same kind of information that you were looking for without using colors or special characters.
Would that help? I'm not completely sure if I have understood the entire thing correctly though.
2445.23 In reply to 2445.22
Thats not it Michael.
I do understand that that new number of an exact .54 displays as .54 even if my decimals are set to 6 or something. That is a proper way for it to be.
My issue "WAS" knowing when the trailing numbers were present.
You fixed this last night with the updated files you posted. The display now reads the decimals I choose and the edit popup now shows these also. Thanks!
________________________
The new post was me speculating that trying to display all the trailing numbers seemed like it may be problematic for your UI. Especially if the decimals were set to a larger value. Say six. The edit popup can handle this, but the display label gets crammed. (This is a natural occurance for what I had originally suggested)
I was just trying to brainstorm a better way to acheive the goal of knowing that .54 was really .540758. while leaving that display label at its old way of displaying a value of just 2 decimal places. Instead of trying the new way of displaying all the decimal places.
It's just food for thought and not to say it is not working for me.
2445.24 In reply to 2445.22
I guess showing trailing zeros would not necessarily let you know that a value was exact, though.
For example if you had a value of 5.45001 and you have 4 decimal places set, it would display as 5.4500 .
But it should help to clarify the level of accuracy for any given number that is displayed though.
2445.25 In reply to 2445.23
Hi Burr, I see what you are getting at.
Really though, I just figure that if you want to set your display to 6 decimal places, it is a natural side effect for that one particular part of the UI to not be able to handle it all...
It seems to be pretty unusual for someone to want to set it to that high of a level, it is totally possible that no existing user actually has it set there for normal work! (if someone is reading this that does have it set that high, please speak up!)
So it's probably one of those things where it is a kind of theoretical problem that does not necessarily need to be solved since probably nobody is actually running into it...
2445.26 In reply to 2445.24
Actually just displaying .54 should mean exact! the way it is set up now.
OIC, Burr hits self on head. You mean I would know if it were not exact because you could at least easily fit the 2 extra zeros!
Yes that works there but you did point out a possible confusion area where one may think that .5400 was then end of it and not edit his entity.
The original UI was very clean and sleak. The question is....Is there a way to visually let the user know that there are exteneded digits on that displayed number, without opening the EditSizeMenu popup? (That does handle it by the way, and you gave me a shortcut to launch it..Very nice, Just thinking of a quicker "visual clue".
For instance this:
Would tell me that the first 2 vaules are exactly as they are displayed, but that .54 actually had more data in the range of my decimal settings and I should further edit or review this with the EditSizeMenu popup. yet keeps your label unclutered with the huge values that Could be created by trying to display all the decimal places out front like that.
2445.27 In reply to 2445.25
I posted myt last response while you were posting your last response.
I can accept your last answer as it does seem no other users are concerned with this area.
You have provided me a fix that works and am satisfied.
Thanks for all the time spent on this for me.
Burr
2445.28 In reply to 2445.27
No problem Burr, I'm glad that this updated system works for what you need, that seems good enough for now! :)
I'm thinking that it still may be a good idea to add a "Show trailing zeros" option anyway, it fits in pretty well just to the side of the decimal display option here:
That will then give you some flexibility to decide if you want numbers displayed like 5.32 or 5.3200 , it is probably good to have this choice.
2445.29 In reply to 2445.28
So now what is the max of decimal point?
2445.30 In reply to 2445.28
Thats perfect and I think that 4 trailing zeros is accurate enough for most stuff. :)
Thanks again
2445.31 In reply to 2445.29
You can find the max setting under Options / General / Decimal display - click the arrow for the dropdown there and look at the one on the bottom, that is the maximum one currently settable in the UI.
Is there a reason why you are concerned about the maximum number? I mean do you expect to need to set the display to have a large quantity of decimal points for some purpose?
2445.32 In reply to 2445.31
Just by curiosity :)
because something had amazing me : in Autocad you can draw the Solar system to the atom at Scale 1 !!!
it's just the number of decimal point (out and in)
I say "draw", not "print"! ;)
Terrific experience! Borgesian story!
EDITED: 26 Feb 2009 by PILOU
of course you must name every object else your mouse whell will died before you click on Pluton! :)
And of course a system of objects is needing too :)
Ps Signature is some strange appears and disapears without reason!
2445.34 In reply to 2445.32
Hi Pilou, even though it is possible to do stuff with such a high amount of fractions or high numeric values, there are a lot of problems that can tend to come up. That's because the basic mechanism that a computer uses to calculate "floating point" numbers only has a limited precision since the numbers have to fit within a limited amount of memory.
It is possible to increase the level of precision with a different kind of approach, but it is usually only done for specialized software because each high precision number starts to take up a lot of memory, and also operations are much slower because they won't use the computer's built in floating point hardware.
With the standard system of floating point numbers, there will be a kind of rounding effect if you try to use values like 0.000000000000000000001 or 1000000000000000000000.23511241251412312312312321 - things very large or very small. It can work, but accuracy gets lost during calculations as numbers snap to the "nearest representable number" for the amount of memory that the number has to use to hold its data.
Floating point numbers have the greatest accuracy when they are somewhat closer to the value of 1.
That doesn't mean that you can't use a range of numbers, if you are dealing with numbers in a range of like 1000000 to 0.0000001 the error level for basic operations is pretty small.
But when you start to talk about tiny fractions or huge numbers of a scale much larger than that, those are usually better to do with software that is set up with specialized types of operations in mind to try and avoid accuracy loss.
2445.35 In reply to 2445.34
Hi Pilou, also in MoI (and other solid modelers) there are also additional issues beyond just the basic accuracy of fundamental arithmetic - MoI and other solid modeling systems often need to calculate results to an approximated level of accuracy.
In MoI this is the fitting tolerance which is 0.001 units in size.
So when you do things like a boolean operation, when MoI calculates the intersection between 2 surfaces it will do some calculations where it continues to increase the accuracy of the result until it is at least 0.001 units from the "true" result. There are many operations for which the completely accurate result is just too heavy to calculate.
So operations that involve this kind of fitting process will not tend to work very well in a solid modeling program if you have objects that are greatly larger or greatly smaller than the fitting tolerance.
That's just another area that tends to make things like modeling a solar system at a scale of 1 to 1 not work very well with a solid modeling program.
Generally with MoI you should try to keep your numbers in a range of something like 0.01 to 3000.0 to get good results.
2445.36 In reply to 2445.28
Will the trailing zero's option reflect the options setting or just be hard coded at 4?
2445.37 In reply to 2445.36
Hi Burr, it works in combination with the number of decimal places setting.
So for instance if you have Options / General / Decimal display: set to show 2 decimal places, if you enable "Show trailing zeros", you will get numbers displayed like 3.00 , 2.30 , etc..
If you are set up to show 4 decimal places and you enable "Show trailing zeros", you will get numbers displayed like 3.0000 , 2.3000 , etc...
This is all set up now for the next v2 beta.
When "Show trailing zeros" is un-checked (which will be the default initially) you will get numbers like: 3 2.3 , where any zeros to the right of the decimal point are removed (and the decimal point itself removed if it was going to be all zeros to the right) - this is the same as in previous versions.
Thx for the very clear explanations as usual! :)
Show messages:  1  2-21  22-38
